I decided to tackle making the hand wheels first. My model drawings show these as single piece wheel/shaft, but it's much easier to make the wheels and shafts separately, especially on the mini-lathe. The scale of this controller constrains how large the hand wheels could be, and I looked at the pendants, and also the radio control car controllers for reference, and decided on 2.5" as a good size. Larger might be better, but this size will allow good gripping of the wheel for precise movements, and the handles will allow for rapids. I had access to some cutoff pieces of 2.5" round 7075 aluminum that served as the stock. I found a .75" long and 2" long piece. On the mini-lathe, the outside jaws on the 3 jaw chuck were used. The .75" piece was faced and turned enough to make it smooth and round, then turned around in the chuck to face the other side to final thickness (0.6"), and then center drilled with #7 drill for 1/4-20 tapping. I waited to tap until after the center was hollowed out to save on tapping depth. Using a boring bar, a pocket of about 1" was cut into the face to a depth of .3" (half thickness of the wheel). With the compound set at 45 degrees, the boring bar was also set to 45 degrees and then the edge of the pocket was worked back until the taper reached the bottom of the pocket. The edges were chamfered, and then the center hole tapped to finish the part. The 2" piece was faced, turned, then turned around to face the other side, and the diameter turned for a distance of about .7". Then I moved to the bandsaw to part off the two pieces about .7" thick. Returned to the lathe to face the cuts to finish thickness (.6") and repeated the center drilling, boring, tapping, chamfering to complete the other two wheels. See attached photos of the finished hand wheels. Each wheel took a little under 2 hours to complete, not fast but the finish turned out nice. I used brazed carbide bits for roughing and boring, and HSS for finish facing/turning. One comment/tip that I've heard about and used here was to keep a set of diamond files handly for touching up the brazed carbide tools. I touched those up after finishing each wheel and it really worked to keep them cutting well. Next up I will get started making the wheel handles and shafts. I have not decided on a handle material yet, chromed steel would be ideal if I could find some pre-made ones at a good price. Delrin might be good also.
