586,409 active members*
3,084 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > U Axis excess error + Y axis over travel?!!!
    Feb 2012
    9
    Post U Axis excess error + Y axis over travel?!!!
    I have A Rollomatic 600X machine with auto loader.
    Machine name : Rollomatic CNC 600X
    Serial no : 346
    Control : fanuc series 16 iM
    It has X,Z axis on horizontal movement and Y is vertical.
    U and W are loader axis .
    problem is it giving
    “W axis excess error(alarm no 410 W axis excess error) "when Unloading the tool to unloading tray “
    at the same time it gives
    Y axis over travel alarm also (alarm no 506) .(actually it moves down at that time and giving the alarm ( but happening fast )
    not ready alarm at back side 7 segment display on all the amplifiers.
    And Y and W are controlling from the same amplifier , other all axes from different amplifier ,
    just listing down some of my observations,
    *some times error not getting while unloading ( If it moves very slowly)
    *error happening only at particular position of the operation
    *W axis (ALL axis) works fine while loading
    *Y axis also not showing any error other than unloading operation .
    *mechanically W axis is smooth.
    *Loading time machine W axis moves normally , there is no problem ,even at the 150% speed
    *if moving this axis with MPG , it moves fine , all the axes
    Please help me to solve this issue!!!!
    Dec 2005
    Quote Originally Posted by jaine View Post
    Serial no : 346
    did you messing with the speed gain already or any acceleration for the w axix yet? excess error ( is not reaching the reference position on time.)
    Luis
    Feb 2012
    9
    it was the problem with it's cable , thanks for your reply
  1. 431 z axis servo excess error
    By bassackwards142 in forum Fanuc
    Last Post: 06-25-2013, 02:46 AM
  2. Mazak QuickSlant 20 with Mazatrol T4 -ERROR 1: SERVO LAG EXCESS X1 AXIS
    By Acustical in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 02-24-2012, 03:44 PM
  3. Replies: 6
    Last Post: 01-14-2011, 05:16 AM
  4. Alarm 410 V axis Excess Error, FIX?
    By D_Flannery in forum Fanuc
    Last Post: 01-14-2011, 05:13 AM
  5. partner 1 Z axis excess error problem
    By blowncoupe in forum Milltronics
    Last Post: 10-18-2008, 03:20 AM
