586,186 active members*
3,786 visitors online*
    Dec 2009
    35
    New DIY Laser - some tips on alignment
    I had requests on my Youtube channel for more information on the trials and tribulations of laser alignment so I put together a movie about it.
    It's long (8 minutes) but (hopefully) there's some good info in it - I've been working with lasers of all kinds for many years and this is the technique that works best for me.
    …new CO2 Laser cutter / engraver…
    Questions welcome!
    Steve
    http://www.stephenhobley.com/blog
    Laser Harps, Tesla Coils, and Killer Robots from Outer Space
    The flashes of light seem to be where the toolpaths cross.
    It's the previously liberated carbon glowing white hot as the laser passes over them a second time after creation
    Nice videos Steve, only suggestion I have is not using masking tape on the mirrors as when it burns through it can chuck glue vapour on the nice shiny mirrors I use 2mm acrylic in small squares that can be clipped onto the mirror holder with Bulldog clips. (They can also be precut on the laser with a crosshair in the middle)
    best wishes
    Dave
    Dec 2009
    35
    Hey thanks - and totally with you on the masking tape - I use the brass shim (most of the time) to stop that from happening.
    Sep 2012
    55
    I use thermal paper (fax roll) kept taught across the front of the mirror by a laser cut plywood ring with a small piece cut out of it so that it is springy.
  1. Tips And Helps for laser engraving art
    By Shade in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-23-2012, 09:05 AM
  2. newbie needs help with laser alignment
    By dominic gailgan in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-10-2012, 09:02 PM
  3. Tips on buying a laser from China
    By bpoulin in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 11-21-2011, 03:48 AM
  4. Tips on moving a co2 laser, anyone??
    By tubeguy in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 03-15-2011, 08:49 PM
  5. Laser Beam alignment
    By graver1 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 01-24-2011, 05:48 AM
