586,822 active members*
3,363 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > wrong ATC arm position-wrong magazine mill position on mori seiki NV4000 DCG
    Nov 2012
    Hello guys! I need your help for once more. I had a problem with my machine's write home positions. I figure out how to solve it for the X-Y-Z axis (red arrows alignment procedure) but.... I cant find the way to set the correct position for the magazine mill (axis [4] i suppose). So i cant work my machine because the atc arm indicator is light off. Neither atc manual mode works. Please anybody knows the procedure for setting the correct position of the magazine's mile?????
    Thank you
    Nov 2012
    I solve it! If anyone needs any information about setting of zero point procedure at mori seiki NV4000 DCG machines, just ask me here!
    Mar 2016
    Re: wrong ATC arm position-wrong magazine mill position on mori seiki NV4000 DCG
    Quote Originally Posted by axieros View Post
    Thank you
    glad to find someone with same CNC issue, i experiencing same problem after removed Magazine drive from a NV500a1, loose the axxis zero, i returned X Y & Z just can't retum M axis to Zero
    How did you solved it?
    Jan 2016
    17
    Thank you
    have the same machine like yours, but im so un lucky lossing all Sram data cause of dead backup battery. can you send me the copy of your backup sram?
    [email protected]
    you save my life by sending the copy, thanks
  1. Mori Seiki SL-25 Z-axis moving wrong amount
    By drlx3 in forum Mori Seiki lathes
    Last Post: 03-21-2014, 03:08 PM
  2. wrong Z position when posting
    By heathj in forum BobCad-Cam
    Last Post: 04-03-2013, 11:54 PM
  3. Canned Cycle Finish Starts in Wrong Position
    By JWB_Machining in forum Haas Lathes
    Last Post: 09-20-2012, 08:44 PM
  4. Lasercut 5.3 -MPC6515 vs wrong position
    By anantblock in forum LaserCut
    Last Post: 06-06-2012, 02:04 AM
  5. Turret in Wrong position
    By chipsahoy in forum Fanuc
    Last Post: 01-20-2010, 02:13 AM
