586,416 active members*
3,900 visitors online*
    May 2012
    98
    Software to create gears
    Wondering what software is available to create aluminum gears. These are gears similar to a bicycle style front gear. These gears are about 8" in diameter and about .100 thick and are about 75 to 85 tooth. The pitch is 219 if that means anything. My son races go karts and these are the gears we run. I thought if I could make our own gears maybe it would save us a little money. The gears we run cost about $17-20 each. Most are anodized aluminum but some are made of a composite material. The aluminum ones usually last about 4 races and have to be replaced.
    Preferably a free or cheap software package. As much as we race anymore we would probably only use about 5 or 6 of them but if the quality is good enough then maybe I would try selling a few.
    May 2007
    428
    Take a look at this link; not sure if it will be helpful or not.
    Gears
    Dolphin CAD/CAM Support
    Dec 2006
    603
    Quote Originally Posted by DHay13 View Post
    Sounds like you want a sprocket not a gear. Google "sprocketeer 2.0"
    I made a sprocket with it but have not had the chance to use it.
    May 2012
    98
    Tried downloading Sprocketeer but it seems as though the site is down. Also watched the video in the link provided by Dolphin...and yes, it is actually a sprocket, not a gear. Sorry.
    Keep the suggestions coming. I'm going to keep searching.
    Thanks.
    Oct 2008
    406
    Bob
    "Bad decisions make good stories."
    Aug 2010
    Download sprocketeer2.0 here
    Sprocketeer | IdleAmusements.com
    It will create .dxf or gcode files.
  1. Which control software lets me create a custom UI
    By Bristol, CT in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-21-2010, 09:53 PM
  2. Help choosing CAD/CAM software that simulates gears and springs
    By en20r954 in forum Uncategorised CAM Discussion
    Last Post: 12-13-2009, 02:56 AM
  3. 123 For Gears Software
    By TWiNMarket in forum News Announcements
    Last Post: 04-05-2009, 12:02 AM
  4. gears
    By georgecort in forum GibbsCAM
    Last Post: 04-21-2007, 12:11 PM
  5. 4 Axis EDM software , used to create foam cutting path?
    By bgriggs in forum CNC Wire Foam Cutter Machines
    Last Post: 09-29-2005, 10:52 AM
