586,971 active members*
3,041 visitors online*
    Sep 2012
    Send/Rec. Programs
    Any thoughts on getting my M32 t0 communicate with MultiDNC software.
    I've stepped through set-up on both ends, tested and double checked all connections, settings, etc. What might I be missing?
    Jan 2009
    55
    Check the stop bits
    Some one at Mazak couldn't count right. Check to make sure the computer is on 7 stop bits and the mazak is on 8.
    May 2003
    323
    rs232
    Make sure the cable works on different machine.
    Did it ever work.
    First try to see if you can receive a program.
    I have done this 2 years ago i do not remember all the buttons
    if you can post screen shoot step by step that would refresh memory.
    I even had a pocket pc hooked up to it to transfer data but only in MAZATROL G-CODE LIKE FORMAT --------- no its not fanuc format.
    Bunch a gcode with numbers and letters.
  1. How do I send/receive NC Programs on Mitsubishi FX EDM
    By barnescomputer in forum Waterjet General Topics
    Last Post: 03-25-2022, 02:32 PM
  2. Going to hook up a network/serial line to send programs directly to machine from pc
    By J S Machine in forum Computers / Desktops / Networking
    Last Post: 05-24-2011, 04:51 PM
  3. How to send programs to mazak t-32 from Mastercam
    By CNC MILL GUY in forum Mastercam
    Last Post: 12-11-2010, 04:54 AM
  4. Fanuc 18M Controller won't send programs!!
    By bkupper23 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-24-2010, 01:38 AM
  5. Do you use SEND ALL for backup?
    By gar in forum Haas Mills
    Last Post: 06-28-2007, 02:19 PM
