cylindrical machining stock,
If you edit your stock and change it from rectangular to cylindrical what you are really doing is setting the software up for 4 axis wrapping.
If you wanted to setup your stock to show like bar stock, you would keep the stock type as rectangular, and use your first setup "display" your stock as bar stock.
Create a solidworks coordinate system in the side view and and select a circle as you stock geometry.
Then create a second machine setup for your machining.
Al DePoalo
Partner Product Manager BobCAD CAM, Inc. 866-408-3226 X147
