586,545 active members*
3,138 visitors online*
IndustryArena Forum > CNC Electronics > Phase Converters > Fuling Inverter DZBSeries
Results 1 to 3 of 3
    Nov 2012
    Hi.
    I have a Fuling Inverter for a CNC Spindle. I have setup the correct parameteres for it to work, but all I have is a flashing OFF sign in the le display. Any ideas why?
    Gerardo Pellicer
    Mar 2011
    22
    Re: Fuling Inverter DZBSeries
    I am getting an issue with the fuling parameter. how and where did you find which parameter was for what?
    Were you able to solve the problem?
    Quote Originally Posted by gerardo.pellice View Post
    Hi.
    Gerardo Pellicer
    Hello,
    I know this thread is old, but maybe someone did find a Solution to the flashing OFF sign on the display. I'm standing in front of the same problem.
    I really would appreciate an answer.
    Dicktl Peatala
  1. Fuling DZB200M Programming mode
    By mutski in forum Phase Converters
    Last Post: 10-02-2021, 10:14 PM
  2. SEtting Fuling DBZ200 Inverter
    By regpugh in forum DeskCNC Controller Board
    Last Post: 03-28-2014, 11:51 AM
  3. Fuling to Huanyang VFD switch
    By futureform in forum Phase Converters
    Last Post: 05-06-2013, 01:49 PM
  4. Fuling Inverter spindle speeds and feed rates
    By alanstclair in forum Chinese Machines
    Last Post: 07-17-2012, 11:21 PM
  5. Fuling DZB200M and Spindle Motor Wiring
    Last Post: 02-26-2011, 06:17 AM
