586,457 active members*
3,337 visitors online*
Results 1 to 7 of 7
    Oct 2010
    121
    TL spindle bearing grease
    Does anyone know what type of grease should be used on the spindle bearings?
    Im getting a rattling noise yet again now that it is colder even though i run the warm up program before using. I want to regrease the bearing so hopefully this wont continue to happen every winter
    May 2004
    4519
    Grease? Do you have a maintenance manual? Might should start there. I tried uploading it, but after 10 minutes gave up.
    Oct 2010
    121
    I only have the operators manual and its not in there. I phoned up haas and they didn't even know and had none in stock. All I know is that its a red grease
    May 2004
    4519
    I think the red grease supplied by Haas is similar to Mystik JT-6 multi-purpose grease that contains less than 15% lithium.
    Oct 2010
    121
    thanks. Ill see if i can find some
    May 2004
    4519
    Dunno about the UK. Here is one possible source: Red 'N' Tacky Grease : Lucas Oil
    Oct 2010
    121
    thanks for the link
  1. High Speed Spindle/ Bearing Grease
    By BRIT-LUBE in forum News Announcements
    Last Post: 02-18-2011, 11:03 AM
  2. I Need Some Spindle Bearing Grease!
    By bjorn toulouse in forum Want To Buy...Need help!
    Last Post: 02-18-2011, 10:50 AM
  3. Linear bearing grease
    By Claude Boudreau in forum Linear and Rotary Motion
    Last Post: 04-11-2008, 05:33 AM
  4. Which Bearing grease?
    By skyline in forum Linear and Rotary Motion
    Last Post: 04-15-2007, 08:10 PM
  5. Bearing Grease
    By georgebarr in forum DIY CNC Router Table Machines
    Last Post: 06-06-2005, 10:07 PM
