586,133 active members*
3,180 visitors online*
    Nov 2012
    Arrow slicer for mach3
    Hi, with a mach3 wizzard you can transform a picture to a 3D gcode file to engrave it, only does it output a gcode that goes straight to total depth you choose.Anyone interested in a slicer, to transform this gcode into slices with depth you can choose ? I wrote the basics for a small program to do this, but need to know how you want to work with it, so I can write the apropriate screens for it.If interested, just tell me what you want to be able to do with it.
    Sep 2012
    1543
    Like Slic3r? Have you used that program?
    Nov 2012
    Hi, no, its the other way around.Slic3R slices from bottom to top, to print something in 3D. I slice from top to bottom, to "engrave" a 3d picture, for instance, starting on the top of a block of material, ending at the bottom.This is needed because you can't engrave in one go a depth of for instance 10 mm with a 3 mm ezngraving bit.
    Have you tried the multipass wizard? It does the same thing.
    Jan 2007
    1795
    can you make an example code?
    i mean like a 50 mm dia half sphere, like a dome, and break down to 3 part the toolpath...
    Nov 2012
    Hi Gerry, I have to check on this wizzard, did not try every one of them out, but will do.Seems to be the same tool.
  1. Harig 618 Slicer Auto Need advise
    By Maglin in forum Uncategorised MetalWorking Machines
    Last Post: 06-10-2012, 12:09 AM
  2. Differences Between Mach3 Mill and Mach3 Plasma?
    By cjjonesarmory in forum Mach Plasma / Laser
    Last Post: 11-18-2010, 04:12 PM
  3. Using Mach3 with Reprap extruderUsing Mach3 with Reprap extruder
    By router101 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 11-03-2010, 10:46 PM
  4. 4to eje con mach3
    By dansa0561 in forum Spanish
    Last Post: 07-31-2008, 04:44 PM
  5. ArtCAM Slicer for download
    By kram242 in forum ArtCam Pro
    Last Post: 10-17-2007, 08:07 PM
