First off, my knowledge is very limited when it comes to CNC machines. I have BobCAD hooked up to a CNC Mill, however my problem is coming with manually programming a Romi G20 CNC Lathe.
Problem: I program a stop M00 then manually move up the tailstock, lock it in place, then advance the quill with the footpedal. It find the center hole and has plenty of pressure. I hit "Cycle Start" once I have the tailstock in place and it won't continue the program.
I tested the program before without touching the tailstock and the program ran just fine.
Anyone have any suggestions of what my problem could be? I also tried to program in the automated quill advance after I manually moved up the tailstock and locked it in place, however no success.
I am not sure where to begin troubleshooting? Anyone have any suggestions.
Also, I am having a small problem as well after tool changes. I program the tool change and the machine doesn't want to move to my next line of programming. I have been alleviating the problem by adding M-Codes such as turning the Spindle on and off after the tool change and it will proceed. Any suggestions for this as well?
Thanks in advance!
Brandon
