586,753 active members*
7,184 visitors online*
Results 1 to 6 of 6
    Apr 2007
    175
    MTW IH clone - Ball screw / servo mount kits?
    Does anyone offer a ball screw/nut and servo mount kit for these machines?
    I currently own one of the IH clones (the bigger of the two) and would love to be able to purchase a ready made kit for it - as I don't have another machine to make the parts on.
    FWIW, I already have the CNC4PC breakout board, geckos, servos etc.
    I'm not totally against buying another smaller mill to do the manual parts on if I have to, but I could be up and running a lot faster if I had a bolt on kit ready to go.
    Mine look a bit like standard-issue screw/nut kits that were roughly cut to length. I didn't write down the part #s before installing them, but I basically just drilled/tapped holes to match the ball kit.
    Apr 2007
    175
    Nice, I hoped it would be that easy.
    The chinese vendor on ebay looks promising, and seemed to be what a lot of people used with decent results.
    Any idea what kind/brand/part number bearings you used on the lead screws?
    Mar 2011
    525
    What are you looking for?
    I have drawings of the ball screws, bearing,bearing blocks I used on MTW mill but I had to make the bearing blocks.
    I don't think there are any ready made kits.
    Kelly
    www.finescale360.com
    Aug 2004
    2849
    Kelly, post any into you have. I've been thinking of getting a MTW IH Clone.
    Thanks,
    Paul
    Mar 2011
    525
  1. Z axis to ball screw or not to ball screw
    By brian257 in forum Bridgeport / Hardinge Mills
    Last Post: 03-28-2012, 09:39 PM
  2. Servo or ball screw
    By hmc710 in forum Bridgeport / Hardinge Mills
    Last Post: 07-15-2008, 06:21 PM
  3. Wanted: V2XT servo/ball screw pullies
    By v488 in forum Bridgeport / Hardinge Mills
    Last Post: 10-23-2005, 03:38 AM
  4. New technology.... old debate.....ball screw vs lead screw
    By trubleshtr in forum Linear and Rotary Motion
    Last Post: 08-16-2005, 02:42 AM
  5. z axis servo on main ball screw or down feed handle
    By replicapro in forum Benchtop Machines
    Last Post: 10-30-2004, 04:25 AM
