Position Page and Relative position
So, we just got a new Haas lathe. We are used to the older Fanuc lathes, so its not that big of a difference. We came across one tho.
In the Fanuc, in MDI if we type:
T1111 G00 X8.9 Z0.
The relative position would be correct to the tool offset
Is there a way to do this in the Haas? If the above is typed, all positions are equal to machine home, and aren't giving the numbers that we want. Now I can do a X8.9 origin, and then the Operator Position will be correct, but is there a way to do this without having to set the position manually?
Sorry if its hard to follow, I know the Haas mills front to back, but not so much on the lathe.
Just when you thought you had it all figured out, all hell breaks loose..
