586,655 active members*
2,296 visitors online*
    Oct 2008
    17
    Exclamation Unloading a program from memory
    Hello,
    so I got this problem with a Hitachi-Seiki HG400III. It has a Fanuc Series 15-M (B) controller. I have ran into an error when dumping all programs from CNC to PC. RAM PARRITY ERROR, CNC-MAIN FILE-RAM. The whole machine shuts down and shows this error. I can reboot it and it's fine. But now, I found wich program caused the error. And since I went into PROGRAM and loaded the one that is causing this into the memory and encountered the same problem. Now every time i start the machine and go EDIT mode and press PROGRAM it tried too load the last program wich now is the one causing the error.
    So is there anyway I could load some other program or delete this one or anything without entering PROGRAM mode?
    Please any tips are welcome!
    // Tony
    Oct 2008
    17
    Managed to solve the problem.
    What I did was I entered MDI and PROGRAM then i could reach the DIRECT MEMORY program library without the machine loading the bogous program.
    Then entered EDIT mode and loaded some other program.
  1. How to save a new 09xxx program to memory?
    By Matt@RFR in forum Haas Mills
    Last Post: 10-08-2012, 07:19 PM
  2. Can't load program into memory
    By 123tool in forum Haas Lathes
    Last Post: 02-15-2010, 05:30 AM
  3. calling up a program from memory
    By Delw in forum Haas Mills
    Last Post: 11-13-2009, 04:30 PM
  4. VF2 Program Memory
    By rrbmachining in forum Haas Mills
    Last Post: 07-27-2009, 10:54 PM
  5. Program Memory problem in FANUC 0i Mate MC
    By ranjankrana in forum Fanuc
    Last Post: 01-10-2008, 10:34 AM
