586,818 active members*
7,562 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol > Mazatrol 640m PC-Fusion-CNC - Crashing when booting
Results 1 to 13 of 13
    Dec 2010
    I lost the BIOS config in my control (battery died) and now I'm not sure if it is configured correctly, and the machine will not start correctly. Can anybody tell me the config that I should see in the "User accessible CMOS area"? Right now, every index (from 70h to 7Fh) is set to [00]h. Is that correct or should there be anything else there?
    If this is correct, what could cause the error I'm having, which is:
    The machine starts and boots in WIN95. After, I see the loading screen for the Mazatrol control, but it crashes, telling me that at64main DLL has crashed (followed by2 other similar programs), and I'm back to windows.
    Is there anything else that might have been lost because the battery died?
    Also, the HDD seems fine. I have a verified working ghost (the ghost was tried in the machine when is was made, and worked fine), so I tried with it and I got the same errors.
    Apr 2006
    3206
    I do hope you had a backup boot disc set with all your parameters...
    My battery died, and the OS did the same thing after I replaced it... didn't want to get out of Win95 into the Mazak screen. Needed to reload.
    I was lucky that I didn't lose programs or existing tools, parameters, etc... it just rewrote what was missing.
    May 2012
    How do you get to the CMOS without an external keyboard?
    Dec 2010
    NSW, I don't know... I used an external keyboard
    But I'm having someone look at the machine this morning, so hopefully, it will be up and running before noon.
    Mar 2009
    109
    If you lost the battery then your SRAM is messed up. You need to initialize and then re-load all data.
    May 2012
    Quote Originally Posted by Rokkin View Post
    I thought of that. But in the past when I had that problem I never had problems with the Mazatrol program starting. It always started and then gave a screen full of alarms due to lost parameter data in the SRAM. He still may have to do that once he gets his other problem solved.
    Dec 2010
    Yup, the control was reinitialized, and the parameters were reloaded, that solve the problem...
    Jun 2012
    Hello, enyone help me with free MAZATROL cad/cam program. Thank you for that
    Sep 2010
    27
    Quote Originally Posted by Fwenk View Post
    Guys, can you help me and describe the step by step procedure of this? I would greatly appreciate it.
    Jan 2011
    350
    Quote Originally Posted by chatjokey View Post
    For Magic 64 with PC, it's:
    Reloading Ladder and Parameters
    1 – Open C:\melpcnc\Mmi32\magictrs.exe
    2 – Using the Transfer program, transfer backup:
    a) USERPLC.LAD in PC to M01\LAD\USERPLC.LAD in NC
    b) ALL.PRM in PC to M01\PRM\ALL.PRM
    c) FILESYS.BIN in PC to M01\PRM\FILESYS.BIN
    d) PARAMET.BIN in PC to M01\PRM\PARAMET.BIN
    3 – Restart the control.
    Note you can reset your NC card from your control panel, hardware, ? category, double click to open the window and you'll have a button for resetting. You need to use your backups done from BEFORE the memory got corrupted.
    Cheers.
    Sep 2010
    27
    guess i have found some info about my problem.
    http://integrexmachinist.com/forums/...m=1&topic=1466
    but there is still nothing about proper loading the data back.
    Sep 2010
    27
    will add a tutorial with screens soon. i know the correct procedure.
    Sep 2010
    27
    here's the link on a great manual. http://victoriacaruk.com/Mazak%20Maz...740MT0201E.pdf
    changing battery, sram clear, backuping, retstoring. all info with pics.
  1. Mazatrol Fusion 640M, Alarm 249
    By Rocketnsam in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 10-31-2016, 12:24 PM
  2. Mazatrol Fusion 640M PLC/Ladder Edits.
    Last Post: 06-05-2014, 04:23 PM
  3. Mazatrol Fusion 640m PCMCIA Card
    By Plastimold in forum Want To Buy...Need help!
    Last Post: 01-18-2012, 03:51 PM
  4. Mazatrol PC Fusion 640M
    By mfugs in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 02-19-2011, 06:06 AM
  5. MAZATROL FUSION 640 ...not booting...
    By dinudesign in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 11-18-2009, 10:12 PM
