Hi !
I am playing around with 3-prong T-nuts (3/8" bolts) and 3/4" plywood for a frame and some components. I am cutting a 1/8" deep 1.05" diameter recess for the nuts to make the surface flush.
Is there any point in applying some epoxy into the recess before inserting and seating the T-nut? Would it stabilize the wood fibres against tearing etc?
Could anyone compare T-nuts with Propells in plywood? I have been buying mine at LeeValley.
Cheers!
