I am still confuse to connect encoder CUI AMT102 V to G320X, correct me if wrong what I will do are as follows:
The procedure for connecting encoder CUI AMT102 V:
1. Determine the optimal encoder line count (45kHz / 40) / 4 = 281.25 equal to 256 count, starting from low value?
2. Set encoder resolution on DIP switch to 0011 = 256
3. SWITCH FUNCTIONS:
a. SW1 Not used
b. SW2 “ON” and SW3 “ON” = Step pulse times 1 (default)
c. SW4 “ON” and SW5 “ON” = +/- 256 count following error limit (default)
d. SW6 “OFF” = Default
e. SW7 “OFF” = Use LIMIT trimpot setting only (default)
f. SW8 “ON”, SW9 “OFF”, SW10 “OFF” = Medium gain 1 (default)
4. Connect the encoder power supply ground to this terminal.
5. Connect the encoder +5VDC to this terminal
6. Connect the encoder channel “A” to this terminal
7. Connect the encoder channel “B” to this terminal
Thanks.
