I am a newbie to the CNC world and am just getting my first machine to the point of running. Just wondering if anyone can tell me if the following is normal before I continue.
I have a G540 controller kit I purchased from Homann Designs about 2 years ago now when I first started on my project of building a cnc router so not sure what version of controller it is.
I have now got the table finished to the point of setting up the motors and control.
I have built up the controller box using the components and diagram obtained from Homann Design and I get a red fault light on the G540 unit with the charge pump switched to the off position and no cables (parallel or motor) plugged in.
I have used a DMM and check that the voltage is being supplied ( I am getting 48.2v at the G540 ports 11/12)
The Estop switch is functioning correctly, the enable switch is functioning to link ports 10/12.
Acording to the Geckodrive data sheets I should be getting a green LED on the G540 not a red fault LED.
Is the G540 working correctly with nothing connected or should I be getting a green LED? Didn't want to go any further plugging things in unless I am sure all is OK to this point.
Thanks in advance for any help
Peter
