Originally Posted by
underthetire
Those little set screws have copper under them. Hope it was still there or you replaced them, otherwise that spindle nut is going to be a B1tch to get off. Easiest way is to leave a tool in the spindle, that reduces the drawbar tension on that sensor nut, thats the only thing holding the drawbar in. If your going to do the drawbar, once the nut is off, put the unclamp cyl back on and eject the tool. At this point the drawbar will be pushing on the unclamp cyl. CAREFULLY unbolt the cyl, and it will pop up a bit. I have all thread with nuts when I do them to eliminate the pop.
