586,396 active members*
3,008 visitors online*
IndustryArena Forum > MetalWorking Machines > Cincinnati CNC > Arrow 750 tool change/tool carosuel issue
    Oct 2012
    Within the past 2 weeks when the machine goes to swap tools, the carosuels moves much quicker to the spindle to swap tools. It is a much more violent motion then normal and happens at about 3x the normal tool change. It has dropped tools due to this. We have troubleshot best we can with no changes or results.
    Nov 2006
    251
    What sort of tool changer does it have ,the swing out arm type or the slide across tool changer.
    May 2007
    64
    Insept
    If you have the swing arm type then there are flow controls on the air cylinder that control the speed of the arm movement. Also at the end of the stroke there are shock absobers to control the stop. If its going to fast then adjust the flow controls. The flow controls control the air exiting the cylinder so adjust accordingly. If it is slamming at the end of the stroke then the shock need replacing. Slowing down the speed can help even if the shock is not that effective any more.
    Rick
  1. tool change issue
    By Diedesigner in forum Uncategorised MetalWorking Machines
    Last Post: 01-26-2013, 05:56 PM
  2. Arrow 500 Tool Change Problem
    By kilunee in forum Cincinnati CNC
    Last Post: 07-03-2012, 08:48 PM
  3. Arrow 1000 tool change problem!
    By Jelle_b_k in forum Cincinnati CNC
    Last Post: 02-24-2011, 07:00 AM
  4. Arrow 500 spindle tool change position
    By mmckell in forum Cincinnati CNC
    Last Post: 02-15-2011, 09:56 PM
  5. Tool change issue
    By GM81 in forum Fadal
    Last Post: 02-11-2011, 06:29 PM
