586,481 active members*
2,929 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > need help bobcad lathe mach3 turn threading
    Feb 2009
    48
    ive tryed all of bobcads lathe pp the one that i find works the best with turning is mach3 lathe rev 1 BUT when threading the lead in on thread passes it done with a g01 from what i gather thats a move with a feed rate not a rapid move well bob cad doesnt post a feed just go1 x lets say .24 should there be a feed rate in that line ? if so how do i edit the pp to make it post that feed or is that a pre determend feed rate in mach and where would i find that setting ? the problem is when it calls g01 the move is soooooooooo slow somthing like 1 ipm or slower
    Feb 2009
    48
    ok so after looking at it some more i guess my first question sounds prity dtupid i get it g01 is a move at the feed rate set in the cam so i guess it has somthing to do with the infeed to the thread g01 works fine in a turning operation but in threading its super slow .07 ipm to be exact so im wondering is it feeding in from the retracted point at a angle and my cv settings are off any help would be apretaisted might have better luck in a mach 3 forum just not sure at this point if its bobcad or mach that my settings are off
  1. need help bobcad lathe mach3 turn
    By hanover owing in forum Mach Software (ArtSoft software)
    Last Post: 10-17-2012, 03:16 PM
