The rapid moves are not displayed on screen because the order the parts get cut in is based on the Cam Part\Milling Tools\Part\Machining Order dialog settings.
There is an easy way to determine and to see how these rapids are taking place and that is to use the Simulation. Any Solids/Surfaces that you create get passed into the simulation and displayed as part of the workpiece element. You can use this to create blocks..or detailed clamps if you wish that will display in the simulation window. In simulation the rapid moves from path to path are shown and you will be able to determine if you have safe moves or not.
Hope this helps
AC
AC
Has anyone seen my pillow?
