586,449 active members*
3,244 visitors online*
Page 4 of 4 234
Results 61 to 74 of 74
  1. #61
    Jun 2013
    32
    I could be wrong, but isn't this the calculation of your maximum lift:
    1kg ~= 35oz so 175oz/in = 5kg/in
    8cm shaft = 3.15 inch
    Max lift = 5/3.15 = 1.59kg
    Edit: oh, are you trying to lift 1kg or 10kg? You mention both values.
    I think even 1kg will be iffy to control as the quoted torque is peak torque. The actual torque varies over the step(?).
  2. #62
    364
    Quote Originally Posted by rinthesun View Post
    I received my drivers and checked the schematic posted in this thread. I have redone the schematic with designations matching the board. As noted before the WARN LED circuit is not correct. Further I have found that two of the unused inverters have been left floating. So there may be noise problems on the board.
    Good job, wich brand are the drives and did you use them already?
    But I don't understand how that idle current reduction can work.
    It's based on C2 wich is charged instantly to 5V by Q1 during the step pulse and then discharged by the 10K resistor.
    The TQ input will be driven high by the 2 inverters when the voltage of C2 reaches +-1.6V, the chip is now in 100% current mode.
    But the timing constant for a 100n and 10K resistor is approx. 1msec. This means that the drive is only in 100% mode for a period of 1msec after reception of a step pulse. I think this is way to short for slow stepping, TQ will only remain high at step rates above +-1Khz. At 1/8 microstepping this would correspond to 0.6 RPS or 36 RPM before full torque is available.
    I guestimate that it takes +- 100msec for the motor to complete and stabilise the actual move of a single step so the timing constant for the RC network should be at least 100 times higher.
    All the above values are not exactly calculated but should be close, I ordered a drive to check this a few days ago.
    I can't wait to see the waveform on the current resistors when stepping at something like 50-100 Hz and compare the low speed torque with the THB6064 drive.
    Open source CNC electronics and accessories:
    http://users.skynet.be/ldt/CNC%20electronics/THB6064AH.html
  3. #63
    364
    The drive arrived yesterday, I expected something similar inside the cover but it's completely different.
    I opened a new thread for this one.
  4. #64
    May 2005
    1397
    Wow CNCZone really makes it difficult to post these days. At least on older computers.
    Luc's new thread about the Chinese TB6600 drivers is here:
    http://www.cnczone.com/forums/steppe...rive_ebay.html
    James hosts the single best wiki page about steppers for CNC hobbyists on the net:
    http://www.piclist.com/techref/io/steppers.htm Disagree? Tell him what's missing! ,o)
  5. #65
    Apr 2014
    Re: Toshiba TB6600
    Hi. Can you help me reduce noise on TB6600HQ driver?
    I create driver by datasheet schematics, but when drive in idle it makes too much noise in some positions (use 1/8 step). Is any way to reduce this noise from drive?
  6. #66
    Feb 2012
    29
    Re: Toshiba TB6600
    Quote Originally Posted by Kochevnik1 View Post
    Check the OSC frecuency (pin23)
    Oscillation frequency fOSC WITH External resistance Rosc = 51 kΩ
    Min 2.8 MHz
    Typ. 4 MHz
    Max 5.2 MHz
  7. #67
    1695
    Re: Toshiba TB6600
    [QUOTE=Kochevnik1;1467864
    I create driver by datasheet schematics, but when drive in idle it makes too much noise in some positions (use 1/8 step). Is any way to reduce this noise from drive?[/QUOTE]
    In a properly done circuit, the 6600 is silent at idle. If it isn't the most likely causes are
    -using wire wound current sense resistors. Replace them with surface mount chip resistors.
    -improper layout. I will comment if you post a photo of your board.
  8. #68
    Aug 2015
    Re: Toshiba TB6600
    Please I'm really struggling with the TB6600 , can any one help me on this thread :
    The Shapeoko Forum ? View topic - PnP Proximity Sensor with the TB6600 Controller
  9. #69
    Re: Toshiba TB6600
    I'm testing with tb6600 driver DIY, because TB6600 is fixed decay mode 40% so stepper motor emits sounds. How do I fix this ?
    Please help me.
  10. #70
    Aug 2011
    388
    Re: Toshiba TB6600
    This is a chopper driver -- I think these always make noisy steppers.
    David Malicky
  11. #71
    Re: Haoyu TB6600 Driver
    sorry, you can example for me ?
  12. #72
    May 2005
    1397
    Re: Toshiba TB6600
    A certain amount of noise is expected when using a chopper driver, but the 6600 is especially loud as far as I can tell... the TB6064AH is much quieter. The Linistepper is very quiet if that is a hard requirement for you. Some research places use it to position sensitive sensor probes, because if they use choppers, the EMF and vibration from the motors swamps the signal they are trying to pick up.
  13. #73
    Re: Toshiba TB6600
    you can check and refered stepper motor at : https://cnc3ds.com/collections/dong-co-buoc-step-motor
  14. #74
    Dec 2019
    4
    Re: Toshiba TB6600
    Very interesting, but I do not have any experience with it.
Page 4 of 4 234
  1. TB6600 drive from EBAY
    By lucas in forum Stepper Motors / Drives
    Last Post: 05-30-2020, 02:59 AM
  2. Haoyu TB6600
    By bobgrant in forum Stepper Motors / Drives
    Last Post: 03-20-2018, 04:57 PM
  3. TB6600 Testing and Troubleshooting
    By Leander86 in forum Stepper Motors / Drives
    Last Post: 06-02-2014, 11:29 PM
  4. TB6600 experiments
    Last Post: 12-22-2013, 06:01 PM
  5. Haoyu tb6600 problem
    By prana7 in forum Stepper Motors / Drives
    Last Post: 08-11-2013, 12:52 AM
