I need some input on configuring my new post for the new system. I've selected the default "BC_4x_Mill.MillPst" post to modify to go with a 4 axis machine selected.
First, in the standard start of file (this will go for toolchanges and such also), the post had "n,rotary_angle" which outputs "just the number" with no A value. The controller, mach3 balks at this. I have changed it to the old output_rotary_angle and it works. Is this correct?
Also, looking at lines 440 and 441, I'm not sure what I need? In the old system, what would be output as a default in place of these settings? At this point I've set these 2 to 0, as I was trying to get rid of Mach3 errors on "inverse feeds". With the other settings, mach3 errors if a rotation angle does not contain a feedrate? Maybe I need to do some settings in my mach3?
I do have another question regarding the feedrates being output, but I will be meeting with my brother in a bit to be sure I know the right questions.
Thanks, I may use this thread a bit until I get situated.
