586,133 active members*
2,767 visitors online*
IndustryArena Forum > MetalWorking Machines > Bridgeport Machines > Bridgeport / Hardinge Mills > Bridgeport Interact 412 Heidenhain 2500 control 4th Axis ?
    Sep 2005
    250
    Hi ,
    I want to add a 4th axis to one of my machines and was wondering if any one has done this or if someone has one for sale that will work directly with my machine control. I already have an extra bosch axis drive board .
    Sep 2005
    250
    Quote Originally Posted by RMARCH View Post
    Hi ,
    Maybe i will look in to a Haas Indexer with a control box.
    Oct 2006
    74
    Same delima
    I been trying to find the answer to your question for about 2 years. Where I'm at is changing the motor on one of my tables. The problem is that only my 4th has the Bosch drive, rest are Siemens, so I don't know what motors work with the Bosch drive. Can you provide me with the servo data from any of your axis.
    Sep 2005
    250
    Quote Originally Posted by BetaBob View Post
    Hi BetaBob,
    The Sem Motors on my Bridgeport interact 412 are MT30M4 -24 and if you have one of the smaller manual tool change series 1 interacts the motors used are MT30R4-58.
    If i find out more information i will post it here.
    Goodluck!!
    Nov 2006
    925
    The Heidenhain will need a sinusoidal encoder signal.probably 11uA,the 100 series control needed 18000 or 36000 ppr and I expect this to be the same but can`t find any info.
    Dec 2011
    63
    Hi guys ... I just posted a new thread outlining the results of my journey through making a functional 4th axis for the Interact. I've been delaying making a post about it as I've been using for a few months without any problems.
    Gridley51, you're exactly right, it takes 18000 or 36000 encoder counts per revolution for a 151B controller ...
    The post is "Functional A-Axis for Bridgeport Interact - It works!", posted 1-5-2014.
    Bottom line - its a practical and doable project for our machines.
  1. bridgeport interact 1 mk2 with Heidenhain 2500 control,
    By General-Jumbo in forum Bridgeport / Hardinge Mills
    Last Post: 09-25-2012, 11:45 AM
  2. Bridgeport Interact - Heidenhain TNC 2500
    By nycooh in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 06-08-2011, 09:01 PM
  3. Bridgeport Interact 1 - Heidenhain 2500
    By nycooh in forum CNC Machining Centers
    Last Post: 07-26-2009, 10:40 PM
  4. Bridgeport interact 412 W/ Heidenhain 2500 control
    By RMARCH in forum Bridgeport / Hardinge Mills
    Last Post: 09-27-2008, 01:06 PM
  5. Bridgeport Interact 1 - Heidenhain 2500
    By nycooh in forum Community Club House
    Last Post: 06-25-2007, 09:56 AM
