Hello Folks,
I am in the process of integrating Kmotion into a lathe style metal spinning machine I am building.
Until this week, I have been using Mach3 with a Smooth Stepper board and a C25 BOB. I have read various instances of Mach causing concern and having what appear to be bi-polar type control issues. Also the inability to customize some of the functions within Mach for my purposes is a problem.
The DynoMotion solution seems to be a more flexible and robust solution on all fronts, with the little issue of needing to know some C programming being a bit scary. I do have some programming experience with other similar languages and am confident that I can learn the necessary steps to achieve my goal. In fact, I found what seems to be a very in-depth C tutorial on the web this morning (400+ pages) and if others are interested, I will post a link to it.
I downloaded the Kmotion software in preparation for moving to that system (once I pass my credit card statement date ) and have been exploring. This morning I opened KnotionCNC and loaded one of my Gcode programs previously created with CamBam and run by Mach. When I hit the execute button, I got a message that the radius to the end of an arc differs from the radius to the start. I suspect that there is a rounding error (existing Gcode is 4 decimal places) and that Kmotion has detected this error. Is there a way to adjust the sensitivity within Kmotion, if this is what the problem is?
Thanks in advance.
