586,096 active members*
3,625 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Left Handed Threading on a Grizzly G0602 10x22 Benchtop Lathe
    Jan 2011
    Is it possible to cut left handed threads on a Grizzly G0602 10x22 benchtop lathe? If not, is there a similar priced lathe that will?
    Is there anyone here that has converted their G0602 to DC power for reduced RPM for threading? If so, what motor and controller did you use?
    Thanks BigSmith
    1943
    TRun machine forward with feed in reverse and tool on front side. Compound set at 29 degrees, but opposite what you would do for right hand threads (With the compund handle toward headstock end). Tool will feed from left to right so you will need an undercut where the tool is positioned for starting the cut.
    If you can't reverse the feed it won't work.
    Oct 2009
    483
    The G0602 does not have the ability to reverse the feed, and so is unable to cut left handed threads - at least as it comes from the factory.
    Several people have made a Reverse Tumbler for the G0602 lathe:
    Projects in Metal - Normans Reverse Tumbler Plans for a Grizzly G0602 10x22 Lathe
    Dennis Atwoods Tumbler Reverse for 10x22 Lathe
    RCDON"s Reverse Tumbler Project
    Some people have converted their G0602 to a DC motor and controller for reduced RPM's, but others prefer the use of a 3-phase AC motor and a variable frequency drive that can take single phase phase in and output three phase power.
    Projects in Metal - Install a VFD on a Grizzly G0602 10x22 Lathe
    Titaniumboy
    Jan 2011
    Thanks Titaniumboy
    I like RCDON's tumbler reverse. Simple and easy mod. No reason to do any reinventing. Much appreciated.
    BigSmith
  1. GRIZZLY G0602 10x22 LATHE UNCRATE & TEARDOWN
    By Crevice Reamer in forum Benchtop Machines
    Last Post: 07-30-2012, 03:54 AM
  2. Grizzly's G0602 10x22 Lathe
    By cobmachine in forum Benchtop Machines
    Last Post: 02-01-2011, 03:26 AM
  3. Grizzly G0602 10x22 Lathe Conversion
    By Steelpolish in forum Vertical Mill, Lathe Project Log
    Last Post: 01-21-2011, 11:04 AM
  4. Just received my G0602 10x22 Lathe
    By mud99 in forum Benchtop Machines
    Last Post: 01-11-2011, 02:12 AM
  5. Replies: 19
    Last Post: 04-08-2010, 06:06 AM
