I would like to use elliptical interpolation in my Hitachi Seiki VA Machining running under Fanuc 6M-B.
Is there a G-code for this ?
If not, how should I proceed ?
Thanks,
Pramod Kotwal
Thanks,
Pramod Kotwal
I have this software for ellipses. Saves money on a big CAD CAM system if you don't already have one. CNC Mate :: Engineers Calculator
Ben
http://www.cncapplications.co.uk
Do you need a true and perfect ellipse? If not, you can approximate an ellipse with 4 arcs. That is how paper draftsmen used to do it. If you search Google for "4 arc ellipse" it will bring up the technique.
Attached is a VB program which will generate GCode for an ellipse.
Hi
is this in MM or inches
thanks
Greetings!
I badly need help for generating G codes(G03) for a CNC 2-axis lathe for turning a ellipse out of a rod. The Rod dia is 12 mm and the ellipse (Full Ellipse) size is 11.5 mm height and 20 mm width. The G-code required is for the section shown in the attachment. The start point is at 0,0 and continues in the Z- axis till 10 mm (Half width of the ellipse). Any help would be appreciated.
Attachment 263986
Thanks in Advance.
Hi I'm a mill user and don't know lathe programming, but here is a suggestion for a start. Check before running.
G01 X0 Z0
G03 X-0.008 Z-0.349 R15.2271
G03 X-0.062 Z-1.045 R17.1512
G03 X-0.174 Z-1.736 R19.3102
G03 X-0.342 Z-2.419 R18.7294
G03 X-0.562 Z-3.09 R18.0439
G03 X-0.838 Z-3.746 R16.782
G03 X-1.164 Z-4.384 R13.9492
G03 X-1.54 Z-5. R13.8463
G03 X-1.966 Z-5.592 R14.6919
G03 X-2.438 Z-6.157 R11.3843
G03 X-2.954 Z-6.691 R9.9005
G03 X-3.512 Z-7.193 R8.9369
G03 X-4.108 Z-7.66 R7.7523
G03 X-4.74 Z-8.09 R7.7858
G03 X-5.406 Z-8.48 R7.4939
G03 X-6.102 Z-8.829 R5.7312
G03 X-6.822 Z-9.135 R4.7587
G03 X-7.566 Z-9.397 R4.7233
G03 X-8.33 Z-9.613 R4.2145
G03 X-9.11 Z-9.781 R3.8193
G03 X-9.9 Z-9.903 R3.6358
G03 X-10.698 Z-9.976 R3.7419
G03 X-11.5 Z-10. R3.3543
Thanks for the reply. I am specifically looking for X, Z, I , K value type of stuff. Secondly, can you recompute the values ? The total height of the ellipse is 11.5 mm and width is 20 mm. The required size is for half ellipse: height 11.5 mm and width 10 mm only. Your code is showing total height of the ellipse as 23 mm.
Thanks in advance.
Hi
I thought I read somewhere the X was a diameter figure.
Try this.
G01 X0 Z0
G03 X-0.004 Z-0.349 I-15.2271 K0.
G03 X-0.031 Z-1.045 I-17.1483 K-0.3167
G03 X-0.087 Z-1.736 I-19.272 K-1.2141
G03 X-0.171 Z-2.419 I-18.6282 K-1.9444
G03 X-0.281 Z-3.09 I-17.8581 K-2.583
G03 X-0.419 Z-3.746 I-16.4883 K-3.1261
G03 X-0.582 Z-4.384 I-13.5928 K-3.133
G03 X-0.77 Z-5. I-13.3337 K-3.7327
G03 X-0.983 Z-5.592 I-13.9276 K-4.6768
G03 X-1.219 Z-6.157 I-10.6189 K-4.1037
G03 X-1.477 Z-6.691 I-9.0396 K-4.0381
G03 X-1.756 Z-7.193 I-7.947 K-4.0882
G03 X-2.054 Z-7.66 I-6.68 K-3.934
G03 X-2.37 Z-8.09 I-6.4282 K-4.3929
G03 X-2.703 Z-8.48 I-5.8622 K-4.6683
G03 X-3.051 Z-8.829 I-4.2286 K-3.8685
G03 X-3.411 Z-9.135 I-3.2582 K-3.4684
G03 X-3.783 Z-9.397 I-2.9026 K-3.7262
G03 X-4.165 Z-9.613 I-2.2626 K-3.5557
G03 X-4.555 Z-9.781 I-1.7037 K-3.4183
G03 X-4.95 Z-9.903 I-1.2687 K-3.4073
G03 X-5.349 Z-9.976 I-0.8719 K-3.6389
G03 X-5.75 Z-10. I-0.4005 K-3.3303
When I open the G-Code in jviewer or SketchNC, I am seeing the following instead of a curved line
Attachment 264068
Is this ok or is some post processing required on the G-Code ?
Thanks in advance.
Hi
Is your software able to check arcing on the XZ plane?
I may not have converted the IJK correct to suit your XZ plane.
I don't have software to check for paths on XZ plane or for a cnc lathe.
Try this. I've changed the X to positive
G01 X0. Z0.
G03 X0.004 Z-0.349 Z0. I-15.2271 K-0.
G03 X0.031 Z-1.045 I-17.1483 K-0.3167
G03 X0.087 Z-1.736 I-19.272 K-1.2141
G03 X0.171 Z-2.419 I-18.6282 K-1.9444
G03 X0.281 Z-3.09 I-17.8581 K-2.583
G03 X0.419 Z-3.746 I-16.4883 K-3.1261
G03 X0.582 Z-4.384 I-13.5928 K-3.133
G03 X0.77 Z-5. I-13.3337 K-3.7327
G03 X0.983 Z-5.592 I-13.9276 K-4.6768
G03 X1.219 Z-6.157 I-10.6189 K-4.1037
G03 X1.477 Z-6.691 I-9.0396 K-4.0381
G03 X1.756 Z-7.193 I-7.947 K-4.0882
G03 X2.054 Z-7.66 I-6.68 K-3.934
G03 X2.37 Z-8.09 I-6.4282 K-4.3929
G03 X2.703 Z-8.48 I-5.8622 K-4.6683
G03 X3.051 Z-8.829 I-4.2286 K-3.8685
G03 X3.411 Z-9.135 I-3.2582 K-3.4684
G03 X3.783 Z-9.397 I-2.9026 K-3.7262
G03 X4.165 Z-9.613 I-2.2626 K-3.5557
G03 X4.555 Z-9.781 I-1.7037 K-3.4183
G03 X4.95 Z-9.903 I-1.2687 K-3.4073
G03 X5.349 Z-9.976 I-0.8719 K-3.6389
G03 X5.75 Z-10. I-0.4005 K-3.3303
I used the G-Code in the software. The Ellipse curve is fine but there is one final issue - The Ellipse section is reverse. It needs to be rotated by 180 degrees (Clockwise). Can you do me one final favor by rotating it ? I need the ellipse section in the +X,-Z sector (as seen in the image attached by me in previous post)
Thanks in advance.
Sorry about that. Give this a try.
G01 X0 Z0
G03 X0.024 Z-0.401 I-3.3543 K0.0005
G03 X0.097 Z-0.8 I-3.7119 K-0.4729
G03 X0.219 Z-1.195 I-3.5293 K-0.8737
G03 X0.387 Z-1.585 I-3.5863 K-1.3137
G03 X0.603 Z-1.967 I-3.7717 K-1.8806
G03 X0.865 Z-2.339 I-3.9882 K-2.5306
G03 X1.171 Z-2.699 I-3.7744 K-2.8982
G03 X1.52 Z-3.047 I-4.2175 K-3.8806
G03 X1.91 Z-3.38 I-5.0583 K-5.5292
G03 X2.34 Z-3.696 I-4.8229 K-6.1122
G03 X2.807 Z-3.994 I-4.401 K-6.382
G03 X3.309 Z-4.273 I-4.5902 K-7.668
G03 X3.843 Z-4.531 I-4.5721 K-8.7816
G03 X4.408 Z-4.767 I-4.6687 K-10.3829
G03 X5. Z-4.98 I-5.2688 K-13.7146
G03 X5.616 Z-5.168 I-4.3487 K-13.1457
G03 X6.254 Z-5.331 I-3.771 K-13.4298
G03 X6.91 Z-5.469 I-3.7821 K-16.3503
G03 X7.581 Z-5.579 I-3.254 K-17.7481
G03 X8.264 Z-5.663 I-2.6274 K-18.5442
G03 X8.955 Z-5.719 I-1.9051 K-19.216
G03 X9.651 Z-5.746 I-1.0127 K-17.1213
G03 X10. Z-5.75 I-0.349 K-15.2231
Sorry, I was not clear in my post. Your G-Code is correct but there is a little modification required. The movement in the -Z axis is 10 mm and +X axis is 5.75 mm. When I plot your G-Code, the ellipse curve is reverse. Image attached below -
Attachment 264220
The ellipse section needed by me is highlighted by the green box in the image below -
Thanks in advance.
I didn't know there could be so many wrong answers.
I don't know why the curve is the wrong way around.
You may need to change the I/K positive/negative. (watch first line, I is different to others.)
Try this version.
G01 X0. Z0.
G03 X0.401 Z-0.024 I0.0005 K-3.3543
G03 X0.8 Z-0.097 I-0.4729 K-3.7119
G03 X1.195 Z-0.219 I-0.8737 K-3.5293
G03 X1.585 Z-0.387 I-1.3137 K-3.5863
G03 X1.967 Z-0.603 I-1.8806 K-3.7717
G03 X2.339 Z-0.865 I-2.5306 K-3.9882
G03 X2.699 Z-1.171 I-2.8982 K-3.7744
G03 X3.047 Z-1.52 I-3.8806 K-4.2175
G03 X3.38 Z-1.91 I-5.5292 K-5.0583
G03 X3.696 Z-2.34 I-6.1122 K-4.8229
G03 X3.994 Z-2.807 I-6.382 K-4.401
G03 X4.273 Z-3.309 I-7.668 K-4.5902
G03 X4.531 Z-3.843 I-8.7816 K-4.5721
G03 X4.767 Z-4.408 I-10.3829 K-4.6687
G03 X4.98 Z-5. I-13.7146 K-5.2688
G03 X5.168 Z-5.616 I-13.1457 K-4.3487
G03 X5.331 Z-6.254 I-13.4298 K-3.771
G03 X5.469 Z-6.91 I-16.3503 K-3.7821
G03 X5.579 Z-7.581 I-17.7481 K-3.254
G03 X5.663 Z-8.264 I-18.5442 K-2.6274
G03 X5.719 Z-8.955 I-19.216 K-1.9051
G03 X5.746 Z-9.651 I-17.1213 K-1.0127
G03 X5.75 Z-10. I-15.2231 K-0.349
You could use line segments for the path and it should look smooth enough.
Try this:
G1 Z0 X0.
Z-0.0015 X0.1004
Z-0.0061 X0.2007
Z-0.0137 X0.3009
Z-0.0244 X0.4011
Z-0.0381 X0.5011
Z-0.0548 X0.601
Z-0.0745 X0.7007
Z-0.0973 X0.8002
Z-0.1231 X0.8995
Z-0.1519 X0.9985
Z-0.1837 X1.0972
Z-0.2185 X1.1955
Z-0.2563 X1.2935
Z-0.297 X1.3911
Z-0.3407 X1.4882
Z-0.3874 X1.5849
Z-0.437 X1.6811
Z-0.4894 X1.7768
Z-0.5448 X1.872
Z-0.6031 X1.9666
Z-0.6642 X2.0606
Z-0.7282 X2.154
Z-0.795 X2.2467
Z-0.8645 X2.3387
Z-0.9369 X2.4301
Z-1.0121 X2.5206
Z-1.0899 X2.6104
Z-1.1705 X2.6995
Z-1.2538 X2.7877
Z-1.3397 X2.875
Z-1.4283 X2.9615
Z-1.5195 X3.047
Z-1.6133 X3.1317
Z-1.7096 X3.2154
Z-1.8085 X3.2981
Z-1.9098 X3.3798
Z-2.0136 X3.4604
Z-2.1199 X3.5401
Z-2.2285 X3.6186
Z-2.3396 X3.696
Z-2.4529 X3.7723
Z-2.5686 X3.8475
Z-2.6865 X3.9215
Z-2.8066 X3.9943
Z-2.9289 X4.0659
Z-3.0534 X4.1362
Z-3.18 X4.2053
Z-3.3087 X4.2731
Z-3.4394 X4.3396
Z-3.5721 X4.4048
Z-3.7068 X4.4686
Z-3.8434 X4.5311
Z-3.9818 X4.5922
Z-4.1221 X4.6518
Z-4.2642 X4.7101
Z-4.4081 X4.767
Z-4.5536 X4.8224
Z-4.7008 X4.8763
Z-4.8496 X4.9287
Z-5.0 X4.9796
Z-5.1519 X5.0291
Z-5.3053 X5.0769
Z-5.4601 X5.1233
Z-5.6163 X5.1681
Z-5.7738 X5.2113
Z-5.9326 X5.2529
Z-6.0927 X5.2929
Z-6.2539 X5.3313
Z-6.4163 X5.3681
Z-6.5798 X5.4032
Z-6.7443 X5.4367
Z-6.9098 X5.4686
Z-7.0763 X5.4988
Z-7.2436 X5.5273
Z-7.4118 X5.5541
Z-7.5808 X5.5792
Z-7.7505 X5.6026
Z-7.9209 X5.6243
Z-8.0919 X5.6444
Z-8.2635 X5.6626
Z-8.4357 X5.6792
Z-8.6083 X5.694
Z-8.7813 X5.7071
Z-8.9547 X5.7185
Z-9.1284 X5.7281
Z-9.3024 X5.736
Z-9.4766 X5.7421
Z-9.651 X5.7465
Z-9.8255 X5.7491
Z-10.0 X5.75
code is for x(radius) not diameter.
The above code will only cut accurately with a sharp tool
this path is for using a 1.25mm corner rad.
(1.25 CORNER RAD. INSERT)
G1X-0.394Z0.
X-0.2875Z-.002
X-0.175Z-.007
X-0.0625Z-.015
X0.0495Z-.027
X0.161Z-.043
X0.273Z-.061
X0.384Z-.083
X0.495Z-.109
X0.6055Z-.137
X0.7155Z-.169
X0.8255Z-.205
X0.934Z-.243
X1.0425Z-.285
X1.15Z-.33
X1.2575Z-.378
X1.3635Z-.429
X1.469Z-.484
X1.5735Z-.541
X1.6775Z-.602
X1.7805Z-.665
X1.8825Z-.731
X1.984Z-.801
X2.084Z-.873
X2.1835Z-.948
X2.282Z-1.026
X2.3795Z-1.107
X2.4755Z-1.19
X2.571Z-1.277
X2.6655Z-1.366
X2.7585Z-1.457
X2.8505Z-1.552
X2.9415Z-1.649
X3.031Z-1.748
X3.12Z-1.85
X3.207Z-1.955
X3.2935Z-2.062
X3.3785Z-2.171
X3.462Z-2.283
X3.545Z-2.397
X3.626Z-2.514
X3.706Z-2.632
X3.7845Z-2.753
X3.862Z-2.876
X3.938Z-3.002
X4.0125Z-3.13
X4.086Z-3.259
X4.158Z-3.391
X4.2285Z-3.525
X4.2975Z-3.66
X4.365Z-3.798
X4.431Z-3.938
X4.496Z-4.079
X4.5595Z-4.223
X4.621Z-4.368
X4.681Z-4.515
X4.74Z-4.663
X4.797Z-4.814
X4.853Z-4.966
X4.907Z-5.119
X4.959Z-5.274
X5.01Z-5.43
X5.0595Z-5.588
X5.107Z-5.748
X5.153Z-5.908
X5.1975Z-6.07
X5.2405Z-6.233
X5.2815Z-6.398
X5.321Z-6.563
X5.3585Z-6.73
X5.3945Z-6.898
X5.429Z-7.067
X5.462Z-7.236
X5.493Z-7.407
X5.522Z-7.579
X5.5495Z-7.751
X5.575Z-7.924
X5.599Z-8.098
X5.6215Z-8.272
X5.642Z-8.447
X5.6605Z-8.623
X5.6775Z-8.799
X5.6925Z-8.976
X5.706Z-9.153
X5.718Z-9.331
X5.7275Z-9.508
X5.7355Z-9.686
X5.742Z-9.865
X5.7465Z-10.043
X5.749Z-10.221
X5.75Z-10.398
hope that helps
