587,012 active members*
3,440 visitors online*
Page 2 of 2 12
Results 21 to 23 of 23
  1. #21
    Jan 2009
    104
    Re: Elliptical interpolation
    X values in a lathe are from spindle center(X0) so when a tool is commanded to go to X0 then the tool should be at spindle center.
    I wrote an application to generate the code I sent, you could look up the math used to create the Elliptical geometry then
    write a macro to generate the path. NcPlot can generate the path using that macro by using the program expand feature.
    hope that helps
  2. #22
    Jul 2003
    1220
    Quote Originally Posted by Kiwi View Post
    .......You may need to change the I/K positive/negative. (watch first line, I is different to others.)
    Try this version.
    G01 X0. Z0.
    G03 X0.401 Z-0.024 I0.0005 K-3.3543
    G03 X0.8 Z-0.097 I-0.4729 K-3.7119
    G03 X1.195 Z-0.219 I-0.8737 K-3.5293
    G03 X1.585 Z-0.387 I-1.3137 K-3.5863
    G03 X1.967 Z-0.603 I-1.8806 K-3.7717
    G03 X2.339 Z-0.865 I-2.5306 K-3.9882
    G03 X2.699 Z-1.171 I-2.8982 K-3.7744
    G03 X3.047 Z-1.52 I-3.8806 K-4.2175
    G03 X3.38 Z-1.91 I-5.5292 K-5.0583
    G03 X3.696 Z-2.34 I-6.1122 K-4.8229
    G03 X3.994 Z-2.807 I-6.382 K-4.401
    G03 X4.273 Z-3.309 I-7.668 K-4.5902
    G03 X4.531 Z-3.843 I-8.7816 K-4.5721
    G03 X4.767 Z-4.408 I-10.3829 K-4.6687
    G03 X4.98 Z-5. I-13.7146 K-5.2688
    G03 X5.168 Z-5.616 I-13.1457 K-4.3487
    G03 X5.331 Z-6.254 I-13.4298 K-3.771
    G03 X5.469 Z-6.91 I-16.3503 K-3.7821
    G03 X5.579 Z-7.581 I-17.7481 K-3.254
    G03 X5.663 Z-8.264 I-18.5442 K-2.6274
    G03 X5.719 Z-8.955 I-19.216 K-1.9051
    G03 X5.746 Z-9.651 I-17.1213 K-1.0127
    G03 X5.75 Z-10. I-15.2231 K-0.349
    Did you get this code to work?
  3. #23
    Mar 2008
    Hi
    is this in MM or inches
    thanks
Page 2 of 2 12
  1. Arc Interpolation
    By QueueJr in forum Rhinocam
    Last Post: 03-21-2014, 07:07 PM
  2. Creating elliptical surfaces/toolpaths
    By BaxterB in forum Mastercam
    Last Post: 09-13-2012, 03:07 AM
  3. Beveled Kerf and Elliptical Circles
    By Shanghyd in forum Waterjet General Topics
    Last Post: 03-12-2010, 07:27 PM
  4. machining elliptical punch and die
    By ikneb in forum G-Code Programing
    Last Post: 07-17-2009, 02:09 PM
  5. interpolation
    By rimcanyon in forum CNC Machine Related Electronics
    Last Post: 04-08-2004, 07:10 AM
