586,608 active members*
3,679 visitors online*
    Oct 2010
    bridgeport vmc 1000 tool changer
    tool dosen't stop under spindle with m6 call it retract 2 to 3 inches and alarms but does stop correctly with tool load button
    Jan 2012
    21
    Check to tool knockout switches. The switches that show that the tool retension is unlocked. The problem is in the tool change cycle. The control is waiting for a finsh signal from a switch. The control has a amount of time it needs to see a signal that something happened. Also it could be the switch that tell the carasel is under the spindle. It is something in the first stages of your tool change cycle. The cycle should be in one of the owners manuals. I am guessing this is a fanuc control with a umbrella style tool changer.
  1. BRIDGEPORT VMC 560 tool changer problem
    By mikemtz123 in forum Bridgeport / Hardinge Mills
    Last Post: 11-11-2019, 10:11 AM
  2. Bridgeport TC3 Tool Changer Repair
    By ThePrecisionist in forum Bridgeport / Hardinge Mills
    Last Post: 04-05-2014, 03:45 PM
  3. Bridgeport interact 412 tool changer does not slow b4 tool change
    By RMARCH in forum Bridgeport / Hardinge Mills
    Last Post: 11-12-2013, 10:50 PM
  4. BRIDGEPORT TOOL CHANGER PROBLEM !!!!
    Last Post: 05-29-2011, 05:23 PM
  5. bridgeport 560 vmc tool changer problema
    By mikemtz123 in forum Spanish
    Last Post: 05-06-2011, 06:30 PM
