We have been kicking around the idea of changing the packaging of the Torus PRO to a single crate. As many have seen from the recent posts the assembly of the machine may have different advantages from a 3 crate system to a single crate delivery.
Obviously, with the single crate, all that is needed is to open the crate and transfer it to the floor. Seems simple but it might exceed the weight limits of a tailgate delivery service if needed. The biggest advantage will be the Torus PRO will be totally assembled and tested except for the coolant wings that will have to be user installed. Garage door heights might also be an issue for garage shops. The bed mill with pallet should be about 7.2 feet.
Are there any customer preferences/opinions that can be shared to help make a good informed decision if we should change this?
Regards,
Novakon Team
