Hi, it's my first time here. I have an error code 2003; z axis feedback error on my 5 axis CNC. Anyone know what it means?
This is what I found in a 8055 M error code pdf
DETECTION: During execution.
EFFECT: It stops the movement of the axes and the spindle, eliminating all the enable signals
and canceling all the analog outputs of the CNC. When detected from the position
loop, it opens the position loop and sets the LOPEN mark to ·1·.
If it is in execution, it interrupts the execution of the part program of the CNC of its
channel.
Besides this, it activates the external emergency output.
CAUSE: The CNC does not receive feedback signal from the axes.
SOLUTION: Check that the connections are properly made.
NOTE: This error comes up on differential axes DIFFBACK(P9) =YES and
sinusoidal axes SINMAGNI(P10) other than 0 when parameter
FBACKAL(P11)=ON Setting parameter FBACKAL(P11)=OFF avoids this error,
but this is only temporary solution.
Thank you
