586,489 active members*
2,113 visitors online*
Results 1 to 11 of 11
    Feb 2010
    69
    DPRNT function on 18i
    Does anyone know how to setup the DPRNT function to works with ethernet...when i punch anything all goes on my computer folder but when i DPRNT nothing goes in my folder and no alarm come out! i never use it but im pretty sure my program is ok
    POPEN
    DPRINT[X#501[44]]
    PCLOS
    any help will be appreciated!
    May 2004
    4519
    I do not think DPRINT works with ethernet. RS-232 only.
    Apr 2009
    1379
    "I do not think DPRINT works with ethernet. RS-232 only. " That is correct.
    Nov 2007
    188
    DPRINT Question
    DPRINT Sorry for asking what is probley a dumb question but what is DPRINT what can you do with it how does it work?
    Apr 2009
    1379
    very briefly, you can use it to send specific data from the control through the serial port. Read the operating manual for your control to see how to use it. Not all controls have it.
    May 2004
    97
    Quote Originally Posted by memoryman View Post
    Correct on an 18i, but incorrect on a Fanuc 30i. You can DPRNT to channel 9 on these machines, though it does require some file manipulation at the PC end.
    May 2004
    4519
    Quote Originally Posted by guypb View Post
    Please explain in detail.
    May 2009
    393
    Firstly you need to setup the COMPUTER & CNC Machine to be able to EXCHANGE DATA.
    Please mention your email ID, so that i can mail you that document.
    Ashish
    Get your CAM Programs rotated by CAS software to REDUCE SETUP TIME on your VMC & HMC. To download it, visit www.computeraidedsetup.com
    Feb 2010
    69
    Thank you guys ! i'll forgot this! ****ing fanuc restrictions!
    Nov 2012
    Does anyone know how to get dprnt to work successfully with a DNC (RS232) software besides using a text command to start and stop the connection? I believe the issue im having is that our DNC software (predator) requires a % sign to start/open and stop/close the connection. The percent sign is needed to upload/download programs, for all the machines so I can't change the start and stop commands in the DNC parameters, like i have seen examples of on other DNC screenshots.
    However, there has to be away around this, many hours of internet research has been done, so any help would be much appreciated, thanks. P.S. Any way of using the Dc2 and Dc4 signals from Popen/Pclos to achieve this?
    Nov 2023
    Re: DPRNT function on 18i
    Is there a way to pull variables out of the machine and store them in .txt file?
    I'd like to record cycle time of every part and calculate average time of mechanical processing.
    Fanuc 0i Model F
  1. DPRNT help
    By DerbyCountyFan in forum Haas Mills
    Last Post: 02-11-2011, 01:56 AM
  2. DPRNT COMMAND
    By harinct in forum DNC Problems and Solutions
    Last Post: 12-21-2009, 11:38 AM
  3. Renishaw DPRNT
    By Ginger_Ninja54 in forum Haas Mills
    Last Post: 10-10-2009, 02:22 PM
  4. Do you use DPRNT?
    By gar in forum Haas Mills
    Last Post: 10-23-2007, 04:02 PM
  5. Macro DPRNT please help
    By MarkoH in forum G-Code Programing
    Last Post: 06-19-2006, 06:37 PM
