Originally Posted by
leemh99
Hello, I have just recently brought a Chinese k40 laser machine. The primary use for the machine is to engrave on pet tags which are made of anodized aluminum.
I have had some success after days of fiddling with the machine and the moshi draw program that come with it.
The problem I am having is when i output to the machine the power/ current indicator drops right down to no more than 5Ma while engraving with the current regulator turned up full.
When i use the test switch with the laser on the current indicator goes up to around 15 - 20 Ma.
I have checked the alignment of the laser, the water is flowing fine and the laser is working but just is not powerful enough.
Any help would be much appreciated.
Leemh99.
