Originally Posted by
Wog
I have some products coming up to be machined on the PCNC1100 with my high speed spindle mounted to a shop-made spindle mount. Worked very well in the past in thin 6061. I've even mounted a Milwaukee portable band saw to the mount for CNC-sawing when I couldn't get a slitting saw to work.
The parts are small, less than 1.5" diameter and made from Kydex, which is an easy material to cut. My idea is to mount maybe 4 separate die-grinders on one mount. Any of you tried this? Or a better question, any reason it wouldn't work?
Maybe after the Tormach lathe comes out, next in line will be a Tormach Waterjet!
Why not make a drive head that will accomodate up to 4 cutters and drive it from the main spindle of your PCNC.
You could use either ER 16 collets, or 1/4 inch set screw type holders depending on your application. I think I would use the ER 16 collet type folders because of the versatility.
You could put your spindles on 2 or 3 inch centers and make 2 to 4 parts at a time.
Just a thought.
You're right though, a lathe would be nice.
