i'm in the process of making a vacuum table for a specific application and have several problems.
The first problem regards the material it's made of: i sourced a piece of HDPA, 20mm thick and threaded a 1/4 npt on one edge. I faced the top surface in the machine to get it flat. Cut the outline channels and grid on the top surface and fitted a gasket all around.
Now is so far from flat that is basically unusable!
I don't want to spend a fortune and use aluminum for it, so what other plastics should i consider in order for it to stay flat once machined?
The other problem i'm having is that the part is not rigid (a guitar top), so it does not press the gasket on the outline all the way down, even though i left it sticking out very little; i tried to make an MDF 'in between' board, attached it and faced it flat, even sealed it's edges, but now the pump can't suck it through hard enough... It's a membrane pump: good depression but low airflow.
I appreciate any help and suggestions to get this thing moving in the right direction!
D.
