Today I was milling some maple with a 3/8" mill and the mill started slipping from the collet in turn ultimately stopping the spindle. I caught it pretty quickly and shut everything down. There was an error message on the spindle (which in my haste I failed to record or remember). I turned off power to the vfd for a couple of minutes, then back on. Whenever I powered up the vfd before it would default to the beginning of the menu system at a--- and I would cycle up to d001 to get the spindle hz readout (I never looked into how to get it to start from there). Now when it powers up, it starts at the hz readout. More importantly, my spindle is only running off of 2 phases, not 3. removing the t3 leg makes no difference in the operation of the motor (which now starts erratic and can spin in either direction by chance) whereas the removal of #1 or 2 stops the motor. I figure I would do both an amperage as well as voltage reading on each leg from ground realizing I would not get a steady readout) Both t1 and t2 are consistent at a low voltage range, but t3 is shoving -140 volts or so. I assume there should be consistency across all 3 phases. I am thinking the vfd may be toast, but I wanted to get a few opinions as to whether I am correct in my assumption or if there is anything else I could look at to either reset the vfd, further testing or salvage this thing. Any input is appreciated. Jay
