Problem with MAZAK VQC 20/40, MAZATROL CAM M-2 control, alarm 256 (head lubrification). Need help !
Thank you
Thank you
Probably a pressure sensor in your headstock. Check your lub oil level, check your oil pressure and then, check your feedback electrical signal. If you have low pressure but sufficient oil levels you could also check your control valves if applicable. Then check your pump.
hi friends anyone help me about VQC 20/40A or B MAZATROL CAM M-2 control parameter.my machine s battery also dead because it wasnt used 3 months or long i must initialise the sytem but i dont have parameters of this machine.
is there anyone send me parameters? i will be really appriciated by any help.
I would contact Mazak. They have always helped me with information. They could get you back on track.
If you have the same machine would you pls take pics of parameters page and send me?ill be very happy if you can.
Hello. I have a copy of parameters for Mazak VQC20/40 and VQC20/50, Part List for VQC20/40, parameter list for Mazatrol CAM M2 and operator manual for Mazatrol CAM M2
My email is [email protected]
