586,635 active members*
3,392 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Best PLace to Buy Gecko G540 w/ 3 Nema 23 motors?
Results 1 to 20 of 32
    Feb 2012
    83
    HI All,
    As a newbie, where is the best place to buy the whole package, G540 and 3 drives with everything I need?
    I saw Keling $455, but I think I need to install the motors resistors and get longer motor wires (not sure where to get these wires)
    Cnc Router parts, $519, looks good and has the resistors and motors wires. Not sure if the $64 extra over Keling is worth it.
    DeepGrover1, $535. Comes with a case and everythng in it, but I think I'm going to make my oun case, plus the motors with this kit are 270oz-in as opposed to 381oz-in for keling and cnc router parts.
    Can I buy all th parts individually for cheaper? And what other places are there?
    dinky
    Jan 2012
    I went the CNC Router Parts route, mostly because I absolutely hate fabbing cables: not having to solder connectors was well worth the money to me. YMMV.
    Feb 2012
    83
    Thanks Lee DeRaud,
    How was it dealing with them? How long after you ordered did you get your stuff?
    dinky
    Jul 2009
    690
    Are you going to use cable carriers?, that might be a deciding factor since some connectors won't fit in some carriers (unless it's the kind that can snap open or similar).
    I've had good experience getting G540s from Hubbard CNC (carolbrent on Ebay) and Keling / Automation Technologies. The latter might be a good alternative if you plan on getting their 381 oz/in motors too (which are very good).
    I usually go with chinese switching power supplies (24V, 36V, 48V), I always use those and IMHO they are pretty good, at least none has failed me.
    Jan 2012
    Quote Originally Posted by dinkyguitar View Post
    Shipping was Priority Mail, about 3 days IIRC (this was back in January). They're very easy to deal with and great after-sale support. Power supply had a broken fan (looked like it happened at the factory), replaced no questions asked.
    Mar 2011
    584
    Mar 2010
    621
    I just bought a G540, motors and power supply from Keeling, package arrived in 3 days.
    I purchased the cables from CNC Router parts, I also didn't want to fabricate cables... they arrived in 4-5 days.
    Pricing was a little better from Keeling.. the motors are not the same so you can't compare them,
    I would buy from either of them again without a doubt, no worries.
    Adam,
    Feb 2012
    83
    Thanks adam_m,
    The motors from Keling, did you have to wire the resistor and crimp the DB9 connectors?
    dinkyguitar,
    Mar 2010
    621
    I'm just getting ready to start my build so I haven't even un-boxed them yet... I did crack the lid to make sure it was there ;-)
    My understanding is that the G540 resistors needed are built into the cables from CNC router Parts which is why I bought them from them (CNC Motor Cable | CNCRouterParts)
    The motors themselves will need to have the connectors added, no big deal, in my opinion. However I wanted to buy a good quality communication cable which is what I think CNC Router Parts is selling, I've not been disappointed with anything from them yet. I think you will get the same response from those on the forum who has used them in the past, good quality products.
    Can someone chime in who has purchased the same cables from CNC Router Parts to let me know if I am incorrect in my understanding of the built in resistor.
    Adam,
    Jan 2012
    Quote Originally Posted by adam_m View Post
    AFAIK, the resistors are in the DB9 connector on the motor pigtail, not the cables. Easiest way to tell is measure the resistance between pins 1 and 5 at either end of the cable.
    That said, I had a problem with motor overheating on the Z-axis (the longest cable). Ahren of CNCRP said it was due to noise in the cable interfering with the G540's ability to read the resistor at the other end. He supplied a set of short stub cables to put at the G540 end that also had the resistors wired in. So it's possible they're implementing it differently in products shipped now.
    Mar 2010
    621
    CNCRP has the following in the description:
    "These cables also feature an overmolded 3.5 kOhm resistor between pins 1 and 5 on the drive (male) connector side, and a drain wire from the shielding to pin 2 of the cable. This sets the current on a G540 to 3.5A/phase to support our motors and popular motors from other vendors, and minimizes electrical noise both to the drive and other sensitive electronics."
    A doubling the resistance wouldn't be good...
    Jan 2012
    It wouldn't double, even if you matched that cable with an old resistor-equipped motor: if the resistor is at the drive end of the cable, there's no need to connect the pin 1/5 wires to the other end, so a resistor at the motor end doesn't do anything.
    This implementation only has one potential problem that I can see: the cables are now motor-current-specific. Not an issue if you're buying a kit, but something to keep in mind if you're doing a mix/match with multiple vendors.
    Feb 2012
    83
    Just an FYI, I was reading the G540 manual and it says that if your using 3.5a motors you don't need a resistor....
    "If your motors are rated below 3.5A you must use a current set resistor across PIN 1 and PIN 5. The resistor is calculated by taking the current in amps and multiplying by 1000. If your motor is rated at 2.8A per phase you will have to use a 2.8K 5% 1/4W resistor. If your motor is rated at 3.5A or above you can safely not use a current set resistor; however, your G540 will not go into current standby mode which will result in increased motor heating."
    But what does this mean? And what resistor would you use on a 3.5a motor??
    "however, your G540 will not go into current standby mode which will result in increased motor heating."
    dinky
    Feb 2012
    83
    So I emailed Keling questioning if their kit
    CNC Stepper Motor Kit: , Stepper Motor, Servo Motor, Power Supply Automation Technology Inc
    comes with a resistor for their motors and their response was, "you may need a resistor which you can get from Radioshack".
    That was just 1 of my questions, and me being a newbie, the fact that they don't even know that question puzzles me. Very short answer to someone who is interested in purchasing their product....Doesn't give me a warm and fuzzy feeling purchasing from them since it leaves me with questionable after purchase support...
    dinky,
    Feb 2009
    1290
    Hi Dinky, in the case of the Keling kit above. They are selling you the steppers and driver not the wiring that goes between them. The resistor is part of that wiring, the G540 has very good wiring documentation. The size of the resistor used may vary depending on the steppers used and what current the user wants to run his/her steppers at. For instance some users may not want to run the steppers at their max current and but rather run them at 80% current, this would require a different resistor than the one used for max current.
    Just a note if you do not run the steppers at max current you will not get their max torque but in some instances that is acceptable.
    Thank You.
    Feb 2012
    83
    Thanks drools,
    I'm glad someone could help me....So, in my case would it be better for me to run the motors without resistors? Those motors are 3.5a max., what would you suggest? Since my machine will be similar to yours....BTW how's your machine w/ 620oz-in motors and 3k resistors?
    dinky,
    Feb 2009
    1290
    Hi Dinky, my large machine works great thanks, very solid and the cuts are very clean.
    My CNCRP 620oz motors are working quite well on the 3K resistor off the G540, of course I do not get the full 620oz from them but I have not had any issues.
    Since my experience is limited to my own builds I cannot really comment on what would be best for you. However there seems to be quite a few good reviews on this combination from Keling and changing or adding a resistor is a minor operation.
    Thank You.
    Jan 2012
    105
    For service AFTER the sale, CNCRP simply CAN NOT BE BEAT. Good luck getting ANY information from Keiling.
    Feb 2011
    Perhaps it's just me and I don't want to sound mean but if you are balking at putting in a resistor you may want to go with a ready built system. Part of the enjoyment does come from the "figuring it out" but if you are going to put it together yourself it can become a lot more complicated. Have you been to candcnc's site. They have electronics all ready to go and it sounds like pretty much plug n play. The g540 comes with excellent documentation on resistor selection and if whoever you purchase from does not include them they are very inexpensive at RS. I bought my G540 from modelshopcnc on ebay and as I recall they sent the resistors as well and had a good price. Hope this helps.
    Feb 2012
    83
    Thanks LazerBee,
    Your not being mean....I just didn't understand what the resistors were for, so I asked questions to someone who supposed to deal with them and they didn't answer me, as if they didn't know...Now granted they may be getting hundred's of emails, but I didn't feel confident in them.
    Anyway, with the help of the members on this forum, I got my questions answered...
    dinky,
  1. 2 Motors 1 Axis Driver in Gecko G540
    By guy2b1 in forum DIY CNC Router Table Machines
    Last Post: 06-10-2012, 04:00 AM
  2. CHOSSING GECKO 540 WITH NEMA 34 STEPPER MOTORS
    By EKFER in forum Mach Software (ArtSoft software)
    Last Post: 06-28-2011, 05:50 AM
  3. mach 3 won't run motors w/ Gecko g540
    By Super Coffee in forum DIY CNC Router Table Machines
    Last Post: 01-20-2010, 07:37 PM
  4. Config for 2 motors on x-axis (w/ Gecko g540)
    By rogerer in forum LinuxCNC (formerly EMC2)
    Last Post: 05-17-2009, 03:30 AM
  5. Nema 34 Motors 434oz/in / which gecko
    By ckrantz in forum Gecko Drives
    Last Post: 10-01-2005, 09:21 PM
