586,461 active members*
3,481 visitors online*
Thread: od turning
Results 1 to 7 of 7
    Sep 2012
    od turning
    can i use a g72 facing cycle for roughing a step block? Can a 80 degree od turn tool be used for this? what is the difference between roughing with g71 and g72? I'm trying to land a programming job that involves mills and lathes. Unfortunately in the past 25 years I have been with mills for 24 and lathes for only one. I need help.
    May 2004
    4519
    No comment.
    Jul 2005
    12177
    G71 cuts along the Z axis and G72 cuts along the X axis. You could machine a step with either canned cycle but it is more conventional to do it using G71.
    May 2004
    4519
    No comment.
    May 2004
    4519
    No comment.
    2932
    Quote Originally Posted by txcncman View Post
    13 hours and no response. This is why you won't be successful with this new job, no dedication or discipline.
    ... not real big on manners, either.
    May 2004
    4519
    No comment.
  1. Turning 17-4 PH?
    By PoiToi in forum CNC Swiss Screw Machines
    Last Post: 12-18-2014, 01:56 PM
  2. Pinch turning or Balanced turning
    By pradeep in forum Mori Seiki lathes
    Last Post: 09-07-2010, 07:55 PM
  3. turning O1
    By grf in forum MetalWork Discussion
    Last Post: 02-19-2010, 11:18 AM
  4. Turning Cam
    By Regnar in forum Uncategorised CAM Discussion
    Last Post: 04-29-2008, 10:27 PM
