586,403 active members*
2,713 visitors online*
    Dec 2006
    112
    SSR and Kress unreliable?
    I have some problems controling my Kress spindle with an SSR relay, It turns on at first but if I turn it off it wont start a second time.
    I suspect this is because the built in speed control rectifies the voltage?
    Is this the problem and is there a way around it?
    Jan 2006
    2985
    Yes, it sounds like the speed control is not letting the triac in the SSR turn on. A simple solution is to use a normal (electromechanical) relay to switch on the Kress. You could still use the SSR to switch the relay to avoid having to fuss with your wiring too much.
    Matt
    Jan 2007
    42
    Had the same problem. The SSR turns on OK but the spindle immediately cuts out. I think it is confused by the leakage current.
    Wiring a 15W pygmy light bulb across the spindle makes it work but I went to a mechanical relay as well.
  1. Mach3 anyone find it unreliable
    By RonCooper in forum Mach Software (ArtSoft software)
    Last Post: 09-04-2011, 07:59 PM
  2. Unreliable, need help in setup
    By ptfo in forum LinuxCNC (formerly EMC2)
    Last Post: 07-31-2011, 10:41 AM
  3. Hi, I'm new here, and need some help with KRESS router
    By Tadas25 in forum DIY CNC Router Table Machines
    Last Post: 07-08-2008, 06:52 PM
  4. kress router
    By brianna187 in forum Want To Buy...Need help!
    Last Post: 04-28-2008, 04:23 PM
  5. buy Kress 900 in Europe
    By ikkedus in forum Mechanical Calculations/Engineering Design
    Last Post: 01-28-2006, 06:06 PM
