586,396 active members*
2,864 visitors online*
Thread: 2D Boundary
    Aug 2012
    15
    2D Boundary
    I use these on most parts that i make and i'm looking to cut down the time it takes to draw them in, does anyone know of a feature that i can use to automatically insert these boxes into each part onto the RefPlane that will dimension them correctly?
    Say the part is 3m i would draw a box at either end around 150mm, and 3 in the middle evenly spaced at around 450mm.
    However, if the part was 500mm i would just need 2 boxes at around 100mm at either end.
    Not sure if this is even possible but i would appreciate any help, if my explaination is hard to understand please say.
    Cheers
    Oct 2007
    499
    You need to talk someone skilled in SolidWorks macro's or DriveWorks.
    Jun 2010
    In solidworks there is a command called linear pattern. Try playing around with that it will do some cool stuff.
    Aug 2012
    15
    Quote Originally Posted by jess fuqua View Post
    wouldn't linear pattern require me to sketch one of the boundaries and work out the dimensions for each of the others?
    I'm looking for the process to be totally automated.
    Quote Originally Posted by Brakeman Bob View Post
    Thanks i will look into this.
  1. Outside of boundary
    By Hoverflyer.mk2 in forum Mastercam
    Last Post: 01-27-2011, 06:16 PM
  2. Keep out / boundary for clamps
    By monstrum in forum FeatureCAM CAD/CAM
    Last Post: 08-24-2010, 05:31 PM
  3. boundary with slice plannar
    By chaz6966 in forum BobCad-Cam
    Last Post: 02-24-2009, 04:50 PM
  4. Boundary box from 9.1 to X?
    By tt_raptor_90 in forum Mastercam
    Last Post: 06-08-2006, 07:24 PM
  5. BobART (v20) 3D Machine to Boundary
    By mc9design in forum BobCad-Cam
    Last Post: 07-24-2005, 12:16 AM
