Hi all,
Designing a 24" x 60" gantry CNC for a specific production purpose. I'd like some ideas based upon the givens below if you have a few moments to respond:
- The gantry will be 24" wide and run on rails the width of the table.
- On the gantry will be a 45 LB motor/spindle.
- The motor/spindle will be on a vertical z axis with linear guides, etc.
- the "Y" travel will be back and forth on the 24" gantry.
- The base will hold a constant jig that will be loaded and unloaded with the part to be cut.
- There are minimal lateral forces during cutting.
I'm thinking of doing the gantry from steel - unless you think I could use extruded aluminum with that weight?
I'm feeling 320 ozin motors for x and y, and a larger stepper up top for the z, like 400+ oz in.
What linear guides would you use for the weight?
Movement speed - probably no faster rapid move than 20 ipm, with slow acceleration.
Please weigh in! I've been out of the CNC building for 2 years since I converted my mini-mill.
Accuracy to about 0.002 would be nice running ball screws.
Thank you!
