586,366 active members*
3,217 visitors online*
IndustryArena Forum > Mechanical Engineering > T-Slot CNC building > Mounting linear guideway on T-Slot?
Results 1 to 8 of 8
    Jun 2012
    Hello!
    I am relatively new to the t-slot profiles, so once I got a scrap piece in my hands I saw something unexpected:
    The parts marked with arrows are somewhat recessed, probably to make the t-nut joint stronger. But what happens if you mount something narrow, like a rail for a linear guideway? Wouldn't it be recessed relative to the profile area? Maybe I need a shim that is as wide as the profile (40mm in my case)?
    Can someone enlighten me please? Thanks!
    Jan 2008
    853
    The recessed slot sides are pulled up flush when you tighten the bolts using standard wide components, so yes, a narrow component may be slightly down unless you use a wider support piece between the rail and the extrusion. I believe the recessed walls make for an internal 'belleville washer' effect, providing some tension on the bolt shaft.
    Any intermediate piece should be sufficiently stiff that the T-slot walls bend, not the added piece. Thin, weak intermediates would give very poor support for your rails, since the rigid rail would be trying to attach to a distorted (curved) shim piece.
    Cheers!
    Jun 2012
    Thanks, Paul!
    So let's say the weight is not a concern, as the rails are mounted on a stationary gantry. Would it be a good idea to use a 40mm wide strip of steel as a shim? Do you think making this steel piece 3mm thick would be enough?
    Also, if the weight is a concern, how thick a strip of aluminum should be?
    Jun 2007
    3757
    3mm steel or 5mm-6mm aluminum I think would be OK.
    Or you could just us big flat panel washers. depends how stiff your machine needs to be.
    You cutter loads, determine how stiff it has to be.
    Once the machine flexes more than the chip thickness, all bets are off, and you have something to chat(ter) about.
    Apr 2014
    24
    Re: Mounting linear guideway on T-Slot?
    I mounted mine by drilling the the slot to the back. used a screw with an angle under the head surface. slid the screws in the slot and slid a allan wrench in from behind through the hole and tighted. The rail centered up perfectAttachment 263570
    Hope the pictures worked.
    Jan 2015
    Hi, Im about to design a machine with this setup, my rails will be wider however ( 35mm ) on 40mm t-slot profile, do you think this problem will affect me? can i do with the washer way?
    Thanks!
    15362
    Quote Originally Posted by noplace View Post
    Thanks!
    A washer I hope was just a joke I think,But you never know what some of the posters are thinking, Linear Rails need to be mounted on a machined surface, it will depend on how much clearance the bearings have, as to how flat the mounting surface has to be, if it is not flat enough for the bearing clearance then there will be binding & jamming of the bearings
    Some suppliers that sell the aluminum extrusion, do offer it with a machined surface, the best way to mount them is on a machined plate with a shoulder, to suit the rail, so the rail can be fitted up against the shoulder, this helps to keep the rail straight
    The rails are not straight, so need a straight/flat surface to be mounted on
    Mactec54
    15362
    noplace
    Here is one that offers a mill surface, for linear rail mounting,( Misumi ) this is still not ideal for linear rail mounting, but for hobby builds, this will help to you build a better machine
    Mactec54
  1. double linear guideway carriage ?
    By turpija in forum Linear and Rotary Motion
    Last Post: 04-12-2014, 06:07 PM
  2. question about load rating linear guideway
    By 15mgtar in forum Linear and Rotary Motion
    Last Post: 07-25-2011, 01:35 PM
  3. question about mounting linear bearing OT
    By 15mgtar in forum DIY CNC Router Table Machines
    Last Post: 07-23-2009, 01:14 PM
