Greetings once again!
I'm running a Mazak CyberTurn 4500MT with a Mazatrol 640 control. I've finished turning the OD on my proof part, and am now needing to turn the ID. Due to tool clearance issues I'm using the lower turret for the boring bar. I'm using MasterCam x6 for the CAM side of things and am having the following problem. Here's an excerpt of the code:
Everything goes fine until I get to N972, which calls a G97 and an M03. I've separated these two commands into separate lines and it goes through the G97 portion just fine, but when it comes to the M03, the machine hangs. No error, no spindle movement, no turret movement, no alarm, nothing. Only a smiling green light above the cycle start button. I've tried removing the M03 just to see, and it progresses happily to the next step. I've tried replacing the M03 with an M04 and the same thing happens. Anybody got any clues?Code:N958 O1000 (DRIVE RING SIDE 1 MARK 3 LOWER.NC) (POSTED 8-23-12 2:38 PM) N960 G0 G18 G20 G40 G80 G97 G99 N962 G109L2 (LOWER TURRET) (***LOWER TOOLS***) (T7 - LATHE TOOL 2) (T9 - LATHE TOOL 3) (T1 - 3/4 SPOT DRILL 8 INCH) (T3 - 17/32 DRILL 12 INCH) (T5 - 5/8-11 TAPRH) (OPERATION 3 ) (LATHE TOOL 1 ) (FRONT SIDE ID ROUGHING) N964 G54 N966 G00 T0505 N968 G18 G99 N970 G50 S800 N972 G97 S407 M03 N974 G96 S500 N976 G00 Z.335 M08 N978 G00 X4.6982 N980 G01 Z.235 F.01 N982 Z-11.141 N984 X4.5 N986 X4.3586 Z-11.0703 N988 G00 Z.335 ...
