Hello all,
Tried searching SFM, but I guess I'm inept at search, because it kept saying no results found.
Anyway, I understand the concept of SFM, but I have a question about it's realistic application. My lathe has a maximum RPM of 4000. I have a 35° profiling insert that recommends 1800 SFM. My finish pass is at 0.94". At that dimension and SFM the RPM should technically be 7314, well above my lathe's maximum RPM. How do you compensate for this? The only variable I could see to change would be feed rate. Do I reduce it to keep the ratio of rpm to feed, or is it inversely proportionate where I would increase feed to compensate for lack of surface feet travelled. Or am I thinking about it all wrong because IPR is IPR, and no matter the RPM it will slow or increase proportionally because it's per revolution? Or am I just thinking too hard??lol The relationships wouldn't be so confusing if there wasn't the caveat of the realistic limitations of my lathe's RPM.
