587,012 active members*
3,408 visitors online*
Results 1 to 20 of 26
    Oct 2008
    248
    Machine rebuilt
    Well it's pretty much done (again lol) I changed out the roller chain with CRP rack and pinion drives. I also change to THK SHS20 and 25mm rails and bearings. The. Machine runs very smooth. I'm getting right around 780 IPM with the 3:1 reduction, I'm running the machine with a G540. The only thing to do now is put the controller and PC in one box and mount to side of machine. What do you think.
    Apr 2005
    253
    Nice build
    I'll get it finished sometime after I start it.....
    Feb 2011
    270
    Quote Originally Posted by mike2768 View Post
    Famous last words! The only thing left to do, is a fill-in-the-blank statement with home built machines. Looking good so far though! Is the speed you are getting recorded from just jogging the machine around, or have you had it actually doing some cutting through Oak, or other hard materials at that speed?
    Oct 2008
    248
    So the speed is just jogging the machine when setting it up. As for cutting speeds I will be do some testing very soon.
    Oct 2008
    248
    Well I made my first part with the rebuilt machine, I must say it came out awesome. The machine still needs some setting tweaked but other then that its great. There's two pictures, one of the part and one of what the machine looks like finished.
ID:	167045 Click image for larger version.
    Feb 2011
    270
    What feed rate did you cut that "First Part" at? Looks great!
    Oct 2008
    248
    Quote Originally Posted by adprinter View Post
    The feed rate was I believe only set at 50ipm it could have handle higher. I really like the way Delrin plastic machine.
    Jan 2012
    but you probably dont like the smell
    Oct 2008
    248
    Quote Originally Posted by bebob1 View Post
    I don't really get any smell from the plastic, I think the trick is not to cut at high spindle speed with slow feed rate
    Oct 2008
    248
    I've been using my machine for a little while now and very please. Now it's time to true the thk rails I have on the machine. What I mean is to make sure they are parallel on the 8020 I'm using. I cut a small bracket to make sure they are, check it out. Click image for larger version.
ID:	176302Click image for larger version.
    Jul 2012
    44
    Very nice, I like that the gantry moves is the Y. That is something to keep in my memory for the future.
    Oct 2008
    199
    finished!
    It won't be long and you'll want tool length sensing, dust shoe with extraction, 4th axis, vacuum hold down......
    Looks great all the same, that part does look awsome
    http://www.cnczone.com/forums/cnc_wood_router_project_log/101936-5_axis_build_full_steam.html
    Oct 2008
    248
    Yeah what was I thinking, they're never really done are they. I'm still looking for ways to make it a better machine 😃
    Oct 2008
    248
    I've been busy lately. I had a little time in the shop today. I cut out a aluminum sprocket. It turned out awesome. What do you think.
ID:	180366 Click image for larger version.
ID:	180367Click image for larger version.
    Apr 2007
    8082
    Yes, awesome it is. Nice work.
    CarveOne
    Oct 2008
    248
    Quote Originally Posted by CarveOne View Post
    Thanks, I'm happy with the edge finish to. Time to put this machine to work and make some $$$.
    Oct 2008
    248
    Oct 2008
    248
    How do I put a direct YouTube link in a post, I forgot :-(
    Jun 2004
    6618
    Copy the address bar in Youtube and paste it in your message. The software takes care of the rest.
    Great looking machine and work.
    Keep it up.
    Lee
    Oct 2008
    248
    Here's the sprocket I made.
    http://www.youtube.com/watch?v=Z-DQSSQSTiA
  1. NM-200 Series 1 Rebuilt *FOR SALE **
    By UniqueMachining in forum Novakon
    Last Post: 04-09-2013, 07:49 AM
  2. Need to get a servo motor rebuilt.
    By JasonR in forum Haas Mills
    Last Post: 02-13-2013, 07:19 AM
  3. A video Of My Newly Rebuilt CNC Machine
    By bsimages in forum DIY CNC Router Table Machines
    Last Post: 10-22-2011, 07:34 PM
  4. Old machine rebuilt
    By thuffner3 in forum DIY CNC Router Table Machines
    Last Post: 04-06-2008, 03:20 AM
