586,648 active members*
2,418 visitors online*
IndustryArena Forum > Tools / Tooling Technology > CNC Tooling > Cutting slots in cardboard tubing
Results 1 to 8 of 8
    Jun 2012
    817
    I'm having trouble cutting clean slots in cardboard tubing on my DIY CNC without the endmill causing ragged edges or fuzzing at the edges of the cuts. Any suggestions on tooling and feedrates/rpm invited.
    Dec 2004
    783
    How thick is the cardboard, how big are the slots, and whats your max rpm?
    Pcb routers come to mind.
    Jun 2012
    817
    Quote Originally Posted by Dylwad View Post
    Tubing is .050" wall, slots are .1875" wide. Max RPM is 25,000. Thanks!
    Jun 2007
    3757
    Use smaller cutter and make a pass along the middle, then a cleanup pass climb milling to finish. Cutter must be really sharp, and watch how quick it wears.
    To make it last longer, on the finish pass use Z ramping down or up move to even the wear on the cutter. Down is probably better.
    Keep the speed down, and feed up bit so there is a positive cutting action.
    If it is not climb milling it will just push the stuff out of the way, hence the first pass to rough out the slot.
    Jun 2012
    817
    Quote Originally Posted by neilw20 View Post
    Thanks for such a detailed response. I'm getting ready to order tooling. Do you suggest upcut or downcut bits?
    Jun 2007
    3757
    Ideally, low helix, downcut can leave burr below. upcut burr above.
    Jun 2012
    817
    Perfect. Burr below is fine, so I'll go downcut. Thanks for your help!
    Jan 2006
    2985
    HSS cutters will cut better when new (they are sharper), but carbide will maintain its performance for a longer time.
    Matt
  1. Laser power for cardboard cutting
    By lucareds7 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 03-31-2011, 05:45 PM
  2. Cutting Tab Slots
    By Intrepidman in forum BobCad-Cam
    Last Post: 03-30-2011, 08:11 AM
  3. Cutting slots at various Z depths ??
    By jwknow in forum Haas Mills
    Last Post: 01-22-2009, 09:02 PM
  4. accurate cardboard cutting?
    By settle in forum Material Machining Solutions
    Last Post: 01-31-2008, 04:49 PM
  5. Machine for making slots in SS tubing
    By ngr1 in forum MetalWork Discussion
    Last Post: 06-23-2006, 07:00 PM
