586,878 active members*
3,295 visitors online*
Threaded View
    Apr 2011
    69
    small co2 laser engraving machine
    laser power: 70-80w
    processing area:300x300mm
    Minimum forming words: Chinese characters 2 x 2mm, letters 1 x 1mm
    carving speed : 0-64000(mm/min)
    cutting speed: 0-36000(mm/min)
    resolution ratio: less than 4000 dpi
    power supply: AC220V±10%
    positioning accuracy: less than 0.01m
    Hang line number: 60 lines
    total power: less than 1250W
    operating temperature: 0~45℃
    Machine weight:50kg
    Operating humidity: 5~95%(free of condensed water) Graphic file format: BMP、JPGE、PLT、CDR、DWG、DXF、DST
    always provide the good resolution of laser cutting,laser marking,laser welding equipment for you. www.hanzlaser.com MSN: [email protected] Skype:lisaseekcn
  1. CMA-6040 Laser Cutting & Engraving Machine by Han's Yueming Laser
    By vksingh in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 11-10-2017, 12:53 PM
  2. Distinction between laser engraving between special LGP engraving machine when produ
    By CUTCNC in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 11-21-2011, 09:46 AM
  3. small Laser cutting and engraving machines
    By keltoh in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-03-2011, 10:27 PM
  4. Supply Laser cutting machine and Laser engraving machine
    By sherryguo in forum News Announcements
    Last Post: 11-27-2007, 02:47 PM
