586,112 active members*
3,123 visitors online*
IndustryArena Forum > MetalWorking Machines > Hardinge Lathes > Hardinge CHNC 1 Power up machine home!
Results 1 to 20 of 29
    Mar 2010
    1852
    Hi All,
    Just got my new (old) CHNC 1 into the shop Tuesday night. Got it hooked up and trying to get everything working now. It is starting to come back to life, slowly.
    I got no manuals what so ever with it, but I have found most of the manuals for the control (Siemens 810T) on line and with help from people like Slant62 on this forum. I found a parts manual and it arrived today.
    Problem is that I can't find a manual from Hardinge with basic operation stuff. Right now I can't even figure out how to do a Machine Home. If some one could advise me on how to do a "machine home" I would appreciate it very much.
    Also, it was supposed to have RS 232 communications, but I can't find anywhere to hook it up. Anyone know where that may be, or how it is wired in?
    Thanks in advance----Mike
    May 2004
    4519
    Upload a picture of the control panel to refresh the memory.
    Mar 2010
    1852
    Some a little blurry, but let me know if good enough. And, disregard the search for the RS232 port, I found it. The cover was stuck and even broke when it finally opened.
    Mike
    May 2004
    4519
    Photo 3 shows a mode select button. I would think it will show mode on screen? Once on zero return or home mode, hold the + feed buttons for each axis until to stops on home? Fanucs usually have a mode select rotary switch. It has been over 14 years since I touched a Hardinge with the Seimens control. Highly recommend you contact Hardinge. They have always helped me in the past, even on older machines.
    Mar 2010
    1852
    Thanks for the assistance.
    I ordered some seals from a Hardinge distributor and some how they messed up the order. Had them over-nighted to arrive on Saturday and one seal was missing. Lost a weekend of work on it time, but talked them into going to the Hardinge site and down loading a manual for me, they have access. Just got back from Staples and having it printed out.
    So, if anyone else needs one I have it now.
    Thanks---Mike
    May 2004
    4519
    Did you have them save it as a PDF file?
  1. Hardinge CHNC I
    By gador007 in forum Mach Lathe
    Last Post: 01-26-2011, 04:12 AM
  2. Need Help- Hardinge CHNC II
    By CatesMetal in forum Hardinge Lathes
    Last Post: 06-22-2009, 04:54 PM
  3. HARDINGE CHNC II
    By MadMan5000 in forum DNC Problems and Solutions
    Last Post: 04-15-2009, 06:33 PM
  4. Hardinge CHNC
    By N4NV in forum Uncategorised MetalWorking Machines
    Last Post: 01-08-2008, 03:58 AM
